You're doing it right. You should look at the dbLoadRecords command that loaded the scaler database to make sure you have the right macro values. If you do, you should do
caget xxx:scaler974.CNT
and see if you can connect. If not, you should look at the ioc console output to see if the database loaded correctly.
Tim Mooney ( [email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Hi tech-talk,
computer : linux redhat6.0 3.14.12.1 synApp5.6
I startup the medm with "medm -x -macro "P=xxx:,S=scaler974" /home/bsrf-non/Documents/synApps_5_6/support/all_adl/scaler.adl", but it could connect.
I think it is the macro value, because I copy it from others( I could not contact him )and it worked well before. Recently, I delete the synApp by careless, it did not work evenif I rebuilt the synApp.
I know nothing about how to set the macro value , could you teach me how to know your macro value.
Thanks for you advice!
Thank you,
Xing Li
- macro value l123173
Re: EPICS installed, making ioc, not working... Shen, Guobao
RE: EPICS installed, making ioc, not working... Arnold, Ned D.
<2015>
2025
2026
macro value l123173
RE: macro value Goetze, Kurt A.
<2015>
2025
2026
ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
