1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS PV updating value
To: bohmm <[email protected]>, Tech talk <[email protected]>
Date: Tue, 21 Apr 2015 13:03:13 +0000
I believe that if you set the MDEL field of the record to -1 then you will receive a monitor every time the record processes, even if the value has not changed.
From: [email protected] [[email protected]] on behalf of bohmm [[email protected]]
Sent: Tuesday, April 21, 2015 7:47 AM
To: Tech talk
Subject: EPICS PV updating value
Hello,
  I have the following record in my database:
# Read latest power measurement
record(ai, "$(head):ReadPower") {
   field(DESC, "Power")
   field(EGU, "$(egu=J)")
   field(PREC, "4")
   field(DTYP, "stream")
   field(INP, "@gnt.proto get_value($(channel)) $(port)")
   field(SCAN, "I/O Intr")
   field(FLNK, "$(head):ReadPowFan")
in the corresponding .proto:
get_value   { in "\$1:%g";  }
The frequency of the external trigger is 0.5 Hz (should expect update
every 2 seconds). However, when I put a camonitor on it (default
camonitor settings):
camonitor HJ-D-P4-EM-2:ReadPower
I sometimes get longer intervals between value updates than 2 second
(multiples, logically), but I need to catch every value of the PV. I
guess it is because the value doesnt change meanwhile:
HJ-D-P4-EM-2:ReadPower         2015-04-21 13:41:21.029564 0.0001036
HJ-D-P4-EM-2:ReadPower         2015-04-21 13:41:23.032038 0.0001267
HJ-D-P4-EM-2:ReadPower         2015-04-21 13:41:27.036535 0.0001497
HJ-D-P4-EM-2:ReadPower         2015-04-21 13:41:29.037671 0.0001152
HJ-D-P4-EM-2:ReadPower         2015-04-21 13:41:33.043594 0.0001036
HJ-D-P4-EM-2:ReadPower         2015-04-21 13:41:35.044982 0.0001382
HJ-D-P4-EM-2:ReadPower         2015-04-21 13:41:37.046880 0.0001152
HJ-D-P4-EM-2:ReadPower         2015-04-21 13:41:39.048397 0.0001267
HJ-D-P4-EM-2:ReadPower         2015-04-21 13:41:43.053185 0.0001152
How do I get the PV value update every time on an external trigger, even
if the value doesnt change.
I apologize for the bad formulation, I am an EPICS newbie.
Thanks
Marek Böhm
EPICS PV updating value bohmm
Prev: EPICS PV updating value bohmm
Next: 2015 EPICS Collaboration Meeting Dinner Eric Berryman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
