1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epicsQt/caWtDM and sliders
To: EPICS mailing list <[email protected]>
Date: Tue, 21 Apr 2015 13:11:14 -0700
John,
1/
What is an increment adjustment when you are using the mouse?
Once the slider is in focus, you can use the arrow keys to single step (refer to the singleStep slider's property).
Note: To focus on the slider using only the keyboard, you need to create a widget buddy (e.g. Ctrl-S to automatically put the focus on the slider)
If want want to use the mouse to single step, you need to "link" a spinbox to your slider (with signals and slots in both directions) and use the arrows of the spinbox.
In this latter case, you need to set the singleStep property  of the spinbox to the desired increment.
2/
I can't help here. I am away from my Qt and EPICS Qt installation!
But what you seem to be seeing is that your focus change in the middle of the move.
Check your OS settings and, if enabled, disable "focus follows mouse".
That may fix your problem.
Emmanuel Mayssat
http://www.epicsqt.org
To: [email protected]
Subject: epicsQt/caWtDM and sliders
Date: Tue, 21 Apr 2015 15:47:25 +0000
All,
I am exploring the Qt display managers options. One of the first things I was interested in checking out were the sliders. (We have several development machines where manual adjustment is a daily part of operations) I find:
1) The epicQt slide has no increment adjustment (? ) Is there anything that would preclude adding this. I don't know where the default increment is set (methods inherited from Abstract Slider?)
2) The caQtDm slider stops following if the mouse pointer moves off the slider knob (?)  If one attempts to move too fast the slider stops following. (Different behavior than EDM/MEDM/CSS.)
John Dobbins
epicsQt/caWtDM and sliders John Dobbins
RE: epicsQt/caWtDM and sliders Emmanuel Mayssat
Prev: RE: epicsQt/caWtDM and sliders Emmanuel Mayssat
Next: Re: epicsQt/caWtDM and sliders John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
