Subject: |
Re: Misunderstanding of epid record ODEL field? |
Ralph Lange <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Wed, 22 Apr 2015 15:05:46 +0200 |
If someone is implementing this,
please be careful:
The documentation at [1] lists ODEL (with ADEL and MDEL) as a "Monitor
Parameter", and specifies "Unless the current value of OVAL is greater
than the amount which the user specifies in this field, no monitors will
be invoked."
There might be people that have configured ODEL per its documentation,
and did not realize they get more subscription updates on OVAL than they
wanted (which can easily be missed). If you change the field's meaning,
they might be surprised that their outputs are not driven every time the
record processes.
Certainly suppressing small steps is a reasonable thing to add, but when
doing it for the OUTL link it might be better to use a new field.
ODEL should definitely also be implemented, so that a record pointing
its DOL to the epid's OVAL.CP can use the ODEL deadband. Maybe that
could be the suggested way to handle this situation anyway, removing the
need to implement similar behavior for the OUTL link.
Cheers,
~Ralph
[1] http://www.aps.anl.gov/bcda/synApps/std/epidRecord.html
On 22/04/2015 14:15, Mark Rivers wrote:
Hi Peter,
Here is a result of a case-insensitive search for the string "odel" in the stdApp/src directory, where the epid record is located:
corvette:std/stdApp/src>grep -i odel *
epidRecord.dbd: field(ODEL,DBF_DOUBLE) {
So the field is defined in the record, but it not used in any of the code. It probably should be implemented, as you suggest, but is not currently.
From: [email protected] [[email protected]] on behalf of Peter Linardakis [[email protected]]
Sent: Wednesday, April 22, 2015 1:08 AM
To: [email protected]
Subject: Misunderstanding of epid record ODEL field?
Hello techtalkers
I am trying to control a motor that drives a slow tuner based on phase and/or amplitude error signals. It’s still just in testing but the basic control works. However, The motor seems to attempt to move on every iteration of the epid loop, even if the magnitude of the epid.OVAL field is less than the epid.ODEL field. Do I understand the intention of the ODEL field correctly? I’d rather not have the motor try to move on every loop iteration. The relevant records are below:
record(calc, "$(res):$(ta):tuning_error") {
field(DESC, "Overall tuning error")
field(INPA, "$(res):$(ta):phase_error")
field(INPB, "$(res):$(ta):ampl_error")
field(CALC, "B-3*A")
record(epid, "$(res):$(ta):tuner:control_pid") {
field(DESC, "PID loop to control tuner postion")
field(INP, "$(res):$(ta):tuning_error CPP")
field(SCAN, ".1 second")
field(SMSL, "supervisory")
field(VAL, "0")
field(OUTL, "$(res):$(ta):tuner:motor.RLV PP")
field(FBON, "1")
field(MDT, "5")
field(KP, "-0.12")
field(KI, "0")
field(KD, "0")
field(EGU, "mm")
field(ODEL, "0.04")
field(DRVL, "-1")
field(DRVH, "1")
field(DISV, "0")
field(SDIS, "$(res):$(ta):tuner:mode CPP")
Thanks in advance
Peter
Dr Peter Linardakis
Accelerator Research & Development Engineer
Nuclear Physics | Research School of Physics and Engineering
Australian National University
e: [email protected]<mailto:[email protected]>
p: +61 2 6125 2862
w: http://physics.anu.edu.au/nuclear/
- Re: Misunderstanding of epid record ODEL field? Pearson, Matthew R.
- Misunderstanding of epid record ODEL field? Peter Linardakis
- RE: Misunderstanding of epid record ODEL field? Mark Rivers
conditional process two records Zhang Yuliang
RE: conditional process two records Arnold, Ned D.
<2015>
2025
2026
<2015>
2025
2026
