1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epicsQt/caWtDM and sliders
To: Emmanuel Mayssat <[email protected]>
Date: Wed, 22 Apr 2015 19:59:05 +0000
Emmanuel,
The mouse focus method for slider control worked with
caQtDM version 3.8.5. That is, version 3.8.5 allows you to
select the slider using the left click mouse button, thereby
by holding down the left mouse button, you can move the
slider from any point on the desktop.
Regards--Jim Stevens
From: [email protected] [[email protected]] on behalf of Emmanuel Mayssat [[email protected]]
Sent: Tuesday, April 21, 2015 4:58 PM
To: John Dobbins; EPICS mailing list
Ok, I understand now.
There are 2 ways to implement this: (1) with a contextual menu, (2) by catching the right mouse click and opening a 'live' dialog.
If I remember correctly, MEDM and EDM use the 2nd approach.
This obviously requires to rework the widget either by subclassing or by modifying it directly.
If you decide to subclass the widget, you will also have to create a plugin to be able to drag and drop your new widget in designer.
I will look in what I can do to help.
You should know that historically the QEFramework (the Australian flavored EPICS Qt) was not intended to reproduce legacy software such as M/EDM.
But caQtDM was. This explains the differences in behavior you are seeing.
Emmanuel Mayssat
To: [email protected]; [email protected]
Subject: Re: epicsQt/caWtDM and sliders
Date: Tue, 21 Apr 2015 20:37:32 +0000
Sorry for the confusion. We generally use the slider in this fashion: give focus to slider by placing mouse pointer over it, then use the keyboard arrow keys to adjust the value up/down. Right click on the slider allows adjustment of the increment, where the increment is the amount the keyboard key press or a click on the slider will change the value by.
John
epicsQt/caWtDM and sliders John Dobbins
RE: epicsQt/caWtDM and sliders Emmanuel Mayssat
Re: epicsQt/caWtDM and sliders John Dobbins
Prev: RE: related to conversion Mooney, Tim M.
Next: RE: Misunderstanding of epid record ODEL field? Peter Linardakis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: epicsQt/caWtDM and sliders Emmanuel Mayssat
Next: RE: epicsQt/caWtDM and sliders Andrew Rhyder
