1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: DBD/DB validator?
To: <[email protected]>, <[email protected]>
Date: Fri, 24 Apr 2015 05:38:52 +0000
Let me point out the Diamond epicsdbbuilder, currently on github at https://github.com/Araneidae/epicsdbbuilder -- this does the opposite side of the job, generating well formed and validated databases from a Python script, using the EPICS database checking API from libdbStaticHost.so to validate against the specified dbd files as the database is built.
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Michael Davidsaver
> Sent: 23 April 2015 17:55
> To: [email protected]
> Subject: Re: DBD/DB validator?
> I'd second the call for a syntax check of .db files.  The fact that
> this
> gets discovered at runtime is terrible.
> I can't count the number of times I've missed (and seen others miss) a
> closing quote, and then miss the error from dbLoadRecord because it
> scrolled off the top of the screen.
> The complicate is that all the parsers in Base are designed to work on
> full definitions.
> On a .db file with only record definitions dbExpand from 3.14 gives:
> > /usr/lib/epics/bin/linux-x86_64/dbExpand -I. cacount.db >/dev/null
> > Record "cnt1" is of unknown type "calc"
> dbdExpand.pl from 3.15 doesn't recognize the "record" keyword.
> > ./bin/linux-x86_64/dbdExpand.pl -I. cacount.db
> > dbdExpand.pl: Syntax error in 'record(calc, "cnt1") {'
> So I can see two courses.
> 1) Modify the makefiles so that the validator can be given .dbd file(s)
> as well.  This would allow (an updated) "dbdExpand ... >/dev/null" to
> serve as a check.
> 2) Write a new utility which parses, but doesn't follow include
> statements, then does as much checking as possible.
> Michael
> On 04/23/2015 05:56 AM, Ralph Lange wrote:
> > Dear all,
> > Ages ago I remember there was a tool called 'dbst' that could be used
> to
> > validate DBD/DB setups and that could dump DBs in a sorted,
> normalized
> > way (only non-default value fields, standard indentation) to make
> them
> > easily comparable with diff and such.
> > Is dbst still around? I suppose there are more recent ways nowadays.
> > Perl/Python? Web-Service?
> > (I do like the idea of using the same library as the IOC, though...)
> > What is a good way to do database validation?
> > Thanks a lot,
> > ~Ralph
DBD/DB validator? Ralph Lange
Re: DBD/DB validator? Michael Davidsaver
Prev: RE: DBD/DB validator? Lang, Keenan C.
Next: Struck SIS3316 Device Support Heinz Junkes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: DBD/DB validator? Michael Davidsaver
Next: RE: DBD/DB validator? Zelazny, Michael Stanley
