1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.15.2-rc1 release
To: "Rivers, Mark L." <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 1 May 2015 00:26:32 +0000
Hi Mark,
Could you try using my Make 4.1 executable instead, which you can find linked from the Base - Windows page under Other Build Tools. I do remember a comment in the release notes about some improvement to parallel builds on Windows in version 4, although I don't know if this will help or not.
I usually use 'make -sj4' to limit the parallelism to 4 which I think might prevent some problems; obviously you can adjust the number of processes to see what works best on your machine. If you don't specify a limit make will keep adding processes until the CPU load gets too high, and I think from experience that's not a very good strategy on Windows.
- Andrew
Sent from my iPad
On Apr 30, 2015, at 5:23 PM, Mark Rivers <[email protected]> wrote:
I tested with a local installation of base-3.15.2-rc1 on my Windows system.
I still saw the problem with “make –j” hanging, with make using 100% of a core.  But the problem was intermittent.  I don’t have a lot of statistics, but it seemed to happen perhaps 50% of the time when using “make –sj” (very little terminal output), and less frequently with “make –j” where there is a lot of terminal output.
If it hung up I was able to kill it and just start it again, so it picked up where the previous hung run had left off.
I was able to successfully build all 4 WIN32 architectures with parallel make, though sometimes having to restart it once to get it to complete.
When it hung with “make –sj” this was the last output before I killed it.  Several times it hung in this same place.
exPV.cc
exServer.cc
exVectorPV.cc
exScalarPV.cc
exChannel.cc
exAsyncPV.cc
Generating code
Finished generating code
The performance with the local build is much faster than the remote non-parallel builds, which took 46 minutes or remote parallel builds on 3.14.12.5 which took 6 minutes.
win32-x86:        2:12
win32-x86-static  2:52
So it was 2-3 times faster than doing a remote parallel make on 3.14.12.5.
This is GNUWin32 make 3.81.
Sent: Thursday, April 30, 2015 3:56 PM
To: 'Ralph Lange'; EPICS Tech-Talk
Subject: RE: Base R3.15.2-rc1 release
Hi Ralph,
I just tested 3-15.2-rc1 on WIN32, and found some problems.
My setup is using a Linux file server that holds a single tree, in which I build for all architectures (Linux, WIN32, Cygwin, vxWorks, Darwin).  I don’t know if that configuration has any bearing on my results.
I found that parallel make does not work on any WIN32 architectures (win32-x86, win32-x86-static, windows-x64, windows-x64-static).  The symptom is that “make” goes to using 100% of a core at some point during the build of libCom, and no further output occurs.  This was the output of “make –j” at the point where it hung building win32-x86-static:
perl -CSD H:/epics/base-3.15.2-rc1/bin/win32-x86-static/mkmf.pl  -m epicsUnitTest.d -I. -I../O.Common -I. -I../../../src
/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../s
rc/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../.
./../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../
../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src
/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libC
om/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I..
/../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../sr
c/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include
         epicsUnitTest.d ../../../src/libCom/misc/epicsUnitTest.c
"make" was using 100% of one core at this point, and nothing further happened.  I had to kill it with ^C.
On base 3.14.12.5 win32-x86-static and windows-x64-static work fine with parallel make, while win32-x86 and windows-x64 do not. The failure for the archs that don’t work is an error reporting a missing .lib file I believe.
The performance is also significantly worse, even for non-parallel make.  These are times I measured today for building the win32-x86-static architecture:
3.14.12.5   parallel make       6 minutes
3.14.12.5   non-parallel make  22 minutes
3.15.2-rc-1 non-parallel make  46 minutes
So it is taking 7.5 times longer to build 3.15.2-rc1 than 3.14.12.5.  This is mostly because I can use parallel make, but even non-parallel make is over twice as fast on the older version.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Ralph Lange
Sent: Thursday, April 30, 2015 2:16 AM
To: EPICS Tech-Talk
Subject: Base R3.15.2-rc1 release
The (first) release candidate for the next release of the EPICS Base
3.15 series 3.15.2-rc1 is now available for download and testing. Please
read the Release Notes to see what's new in this release.
         http://www.aps.anl.gov/epics/base/R3-15/2.php
Please test - especially if you have less widespread OS/architecture
setups that you can test on - and report feedback and any problems you
encounter here on the tech-talk list.
Note that some support modules may require changes to build properly
with this release, so check with a module author to see if they have a
3.15 version available if you encounter problems.
If no major issues arise with this code, the final 3.15.2 release will
be created in the second week of May. Thanks to everyone who has
contributed towards this release, and especially to the other core
developers for all their work.
~Ralph
RE: Base R3.15.2-rc1 release Mark Rivers
Base R3.15.2-rc1 release Ralph Lange
Prev: RE: Base R3.15.2-rc1 release Mark Rivers
Next: RE: Problems using static database routines to modify IOCs Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Base R3.15.2-rc1 release Mark Rivers
