1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS and multiple IOCs
To: Franklin Fuller <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 07 May 2015 10:02:12 -0400
On 05/07/2015 01:25 AM, Franklin Fuller wrote:
Hello,
My problem is: I have two soft IOCs running on a Mac (Yosemite) and I
can't seem to get CSS to connect to both simultaneously.  CSS connects
to each individually without issue.  In the terminal, I can use
caget/caput to drive both devices simultaneously.
I see this problem has shown up in this email list before, but the
suggestion seems to be to fix the CA.  As I'm able to get caget/caput to
work, though, I'm not sure it's a problem with CA.  Frankly, it's not
yet clear to me where exactly one should modify the myriad of
environment variables discussed.  The best I've found so far is two
variables defined in base/startup/Site.profile.  Currently I have:
  EPICS_CA_AUTO_ADDR_LIST=YES
  EPICS_CA_ADDR_LIST="xx.xx.19.255 127.0.0.1"
Where in the second I put both the "broadcast" IP and the local IP.
I've tried various settings here.  No solution yet.  I have also put
these into my ~/.bash_profile for good measure.
I also see the opposite of what others report: the first ioc started is
the one that CSS connects to, not the last.
~Franklin
Ralph Lange solved this problem and wrote a very nice summary of
his solution here:
https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host
We had the same issue, implemented Ralph's suggested changes, and it
resolved our situation very nicely.  Our system administration staff
thought this might cause the relevant computers to actually rebroadcast
over the network, but there is no additional network traffic...
all extra communication stays local to the computer running multiple soft IOCs.
Matthew Bickley                                 Email: [email protected]
Deputy Head of Accelerator Operations           Telephone: 757-269-7347
TJNAF
Re: CSS and multiple IOCs Kasemir, Kay
CSS and multiple IOCs Franklin Fuller
Prev: Re: CSS and multiple IOCs Benoit
Next: Re: CSS and multiple IOCs Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS and multiple IOCs Franklin Fuller
