On 05/13/2015 02:52 PM, Jameson Graef Rollins wrote:
> This program utilizes two processes: a "main" daemon process and a
> "worker" sub-process. The daemon holds the PCAS, while the worker uses
> pyepics to do the work.
> Attached is the gdb bt output for the threads of both the "MAIN" and the
> "WORKER" for one of these wedged nodes. Like I said, I'm pretty sure
> the problem is in the PCAS, so I think the problem is in the MAIN, but I
> include the WORKER bt for completeness.
> I don't actually have a wedged node right now, so I can't get any more
> info until it happens again. If there's some other gdb info I can
> retrieve next time this happens, please do let me know.
The thread in question (it's sitting in cantProceed()). It is indeed in
a PCAS call (see below).
One odd thing I notice. It seems that GDB finds the debug symbols for
libCom, but not for libcas. It seems unlikely that this would be true
if both libraries were from the same build. Also I note that libca is
being loaded from a slightly different path (symlink?).
> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libCom.so.3.14...done.
> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14...(no debugging symbols found)...done.
> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
This might just be a quirk of GDB searching though. Can you check on a
running process ("cat /proc/<pid>/maps") to see which libraries were loaded?
Also, running "ldd -v _pcas.so" might be interesting.
FYI I'd recommend setting SHRLIB_VERSION to something more specific than
"3.14".
> Thread 1 (Thread 0x7f8658d49700 (LWP 26265)):
> #0 0x00007f8658933d84 in pthread_cond_wait@@GLIBC_2.3.2 () from /lib/x86_64-linux-gnu/libpthread.so.0
> #1 0x00007f86529ed809 in condWait (mutexId=0x301f080, condId=0x301f0a8) at ../../../src/libCom/osi/os/posix/osdEvent.c:75
> #2 epicsEventWait (pevent=0x301f080) at ../../../src/libCom/osi/os/posix/osdEvent.c:137
> #3 0x00007f86529ec158 in epicsThreadSuspendSelf () at ../../../src/libCom/osi/os/posix/osdThread.c:557
> #4 0x00007f86529e2d05 in cantProceed (msg=<optimized out>) at ../../../src/libCom/misc/cantProceed.c:69
> #5 0x00007f8652568525 in casPVI::getExtServer() const () from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14
> #6 0x00007f8652c2efa3 in PV::postEvent (this=0x30a0200, value=...) at pcaspy/pv.cpp:83
> #7 0x00007f8652c1fdc9 in _wrap_PV_postEvent (args=<optimized out>) at pcaspy/casdef_wrap.cpp:9193
> #8 0x0000000000571b58 in PyEval_EvalFrameEx ()
- RE: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Mark Rivers
- Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
- "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
- Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
Re: EPICS training sessions Bob Gunion
<2015>
2025
2026
<2015>
2025
2026
