1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A issue when trying to use modbus module
Date: Fri, 15 May 2015 14:59:52 +0000
I received the message below last night from someone named John.  I believe it is a legitimate messages asking for help on Modbus.  However, it appears to come from a blacklisted e-mail address at Argonne, so I cannot reply directly.
I am hoping that the sender reads tech-talk, so here is the reply.  Please either use tech-talk to reply or send a message from another e-mail address.
Your record has probably not yet been processed, since SEVR=INVALID and STAT=UDF.  Please send your sim1.cmd (renamed to .txt so it gets though the mailer) and the database you used.
Hi Mark,
I am trying to test the modbus module on EPICS, I am using the sim1.cmd to connect with a modbus slave simulator. It looks connection is OK, there is no any warning message in IOC site. But when I modified the coil value in simulator slave , I use the dbpr command to verify it , I can't find any change:
dbpr SIM1:BO0B
ASG:                DESC:               DISA: 0             DISP: 0
DISV: 1             NAME: SIM1:BO0B     RBV: 0              RVAL: 0
SEVR: INVALID       STAT: UDF           TPRO: 0             VAL: 0
I config the modbus slave simulator is :
address : 0001
length : 128
modbus point type : 01:coil status
I think it should be right because I use modbus server to verified it. The simulator server always can read the simulator slave variables correctly.
Did I miss something?
Thanks
John
Prev: EPICS Base 3.15.2 released Ralph Lange
Next: scalcout fails to write to bo Isabella Rey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
