1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asyn, modbus and other modules moved to github
To: EPICS Tech-Talk <[email protected]>
Date: Sun, 24 May 2015 00:23:44 +0000
Folks,
I have switched the repositories for all of the EPICS modules for which I am responsible from Subversion at the APS to git on github.com.
The modules are in the "epics-modules" project, https://github.com/epics-modules.  This is the same project with Stephanie Allison's iocStats and Ralph Lange's MCoreUtils.
These new repositories are:
asyn
camac
dac128V
dxp
ip330
ipUnidig
mca
measComp
modbus
quadEM
All previous tagged releases are available for each module as tar.gz or zip files.  Users who want to test the latest version can clone and checkout the "master" branch.
If you find a problem with a module please create a new github "Issue".
If you would like to contribute a change please use the github "Pull request" mechanism.
Cheers,
Prev: Re: CA client broadcast brings down galil which is not running EPICS Heinz P. Junkes
Next: Re: CA client broadcast brings down galil which is not running EPICS Mark Clift
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA client broadcast brings down galil which is not running EPICS Henrique Almeida
Next: Draft requirements document for enhanced EPICS motor support Mark Rivers
