Hi Florian,
Yet another thing to keep in mind is the level at which you want locking
of things to happen.
Usually (in the blocking case), a port driver locks its port, does the
IO, then unlocks its port.
Some years ago at BESSY we were thinking how our CAN-Bus driver would
fit the ASYN model. CANopen compliant, i.e. many nodes per bus (~30),
many variables per node (~15), and some types of indexed variables with
many values per variable (~120).
The only thing that we wanted to be locked (between request and reply)
was the variable, to avoid sending commands on two different indexes of
the same variable without waiting for an answer.
Something like that does not fit the ASYN model well. For each fully
populated bus segment you would basically end up with ~450 instances of
a blocking "variable" port driver, all talking to the same non-blocking
lower level "bus" port driver. Starting 450 threads per bus made this
look very unattractive.
In the end we kept our patchwork non-ASYN driver, as (for this and other
reasons) the rewriting effort was not justified well enough.
~Ralph
- Re: Question about device support Florian Feldbauer
- Question about device support Florian Feldbauer
- RE: Question about device support Mark Rivers
<2015>
2025
2026
<2015>
2025
2026
ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
