1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problems with asyn read calls at driver exit
To: [email protected]
Date: Thu, 28 May 2015 15:39:02 +0200
I'm developing an EPICS driver using asynDriver and I'm having problems with the finalization of the driver. The function that frees all the resources allocated and closes the session with the hardware driver is registered with epicsAtExit. The problem here is that some PVs have timed scans and the driver is receiving calls to the registered read methods after the ioc exit call.
What is the best way to avoid read calls when closing the driver?
Should I unregister manually my driver from the asyn interfaces?
Any help or hint about this will be appreciated.
Sergio.
Sergio Esquembri
Technical University of Madrid
Instrumentation and Applied Acoustic Research Group
Crta Valencia Km-7
Madrid 28031
Phone(R&D Lab): 913364696 Ext: 29400
email: [email protected]
Disclaimer:
This e-mail message may contain confidential information and/or legally
privileged and is intended only for the use of the addressed person. Any
disclosure, copying, distribution or the taking of any action in reliance
on the contents of this e-mail by any other person is strictly prohibited.
If you believe that it has been sent to you in error, please reply to the
sender that you have received the message in error, then delete this
message from your system. Thank you for your cooperation.
RE: Problems with asyn read calls at driver exit Mark Rivers
Prev: SAES NEXTorr NIOPS-04 Vacuum Pump Power Supply John Dobbins
Next: RE: Problems with asyn read calls at driver exit Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SAES NEXTorr NIOPS-04 Vacuum Pump Power Supply Bob Gunion
