1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Draft requirements document for enhanced EPICS motor support
To: "Mooney, Tim M." <[email protected]>, "Rivers, Mark L." <[email protected]>, "[email protected]" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Tue, 2 Jun 2015 08:49:13 -0500
On 5/26/15 11:28 AM, Mooney, Tim M. wrote:
> I started to edit the requirements document, but the premise seems
> to be that we would like to get rid of the motor record if only we
> could.  I don't feel this way.  I think it's a very valuable
> implementation of the behavior needed for nearly all the motors on
> APS beamlines.  An important but small number of motors need a
> better model to do complicated motions, and I'd like to focus my
> effort on those needs, without also pursuing the goal of
> reimplementing stuff that works.
One of the reasons I have thought about rewriting or replacing the motor
record in the past is that the motor record was not designed to handle
multiple fields changing simultaneously.  Here is an example:
1. Change a motor's VAL field using an NPP link from another record in
the IOC
2. Set the motor's STOP field to one using an NPP link from another
record in the IOC
3. Process the record once by writing 1 to the PROC field; the motor
record sends the stop command to the controller and resets the STOP field.
4. Process the record a second time; this moves the motor to the VAL
specified in step #1.
Note: The behavior is the same when PP links are used to write to a
motor record that is disabled (DISA=DISV,DISP=1).
This failure to handle multiple field changes has resulted in motors
moving when users were trying to redefine a motor's position.
Another reason I've wanted to enhance the motor record is that I've
found it to be the obstacle when trying to implement multi-axis
coordinate transforms of arbitrary motor axes using motors with
soft-channel device support in such a way that all the target positions
stay synchronized.  I can elaborate on that if falls within the scope of
this discussion.
Kevin
Re: Draft requirements document for enhanced EPICS motor support Torsten Bögershausen
RE: Draft requirements document for enhanced EPICS motor support Mooney, Tim M.
Draft requirements document for enhanced EPICS motor support Mark Rivers
Prev: EPICSQt version 3.1.0 released Andrew Rhyder
Next: Rotating or deleting procServ log files Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Draft requirements document for enhanced EPICS motor support nick.rees
Next: Re: Draft requirements document for enhanced EPICS motor support Torsten Bögershausen
