> I started to edit the requirements document, but the premise seems to be that we would like to get rid
> of the motor record if only we could.
I did not mean to imply that. The only place I suggested replacing the motor record was in the "Strawman for Proposed Implementation". I intended that to be what it says, a strawman to start a discussion.
Sent: Tuesday, May 26, 2015 11:28 AM
To: Mark Rivers; [email protected]; EPICS Tech-Talk
Subject: RE: Draft requirements document for enhanced EPICS motor support
Hi Mark,
I started to edit the requirements document, but the premise seems to be that we would like to get rid of the motor record if only we could. I don't feel this way. I think it's a very valuable implementation of the behavior needed for nearly all the motors on APS beamlines. An important but small number of motors need a better model to do complicated motions, and I'd like to focus my effort on those needs, without also pursuing the goal of reimplementing stuff that works.
However, I also agree that at least some of the state-machine aspects of the algorithm the motor record mplements would be much easier to code and maintain in a driver, because a driver can block and a record can't. On the other hand, a record has a special() routine and a driver doesn't.
In any case, I would like to retain at least one behavior of the motor record: the ability to set a speed, start a motion, and then immediately return the speed to its previous value without affecting the motor motion in progress. The table and monochromator software expect this behavior. It's certainly possible for software to wait until the motor has finished moving to reset the speed, but it's more complicated and error prone to do this.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Monday, May 25, 2015 3:03 PM
To: [email protected]; EPICS Tech-Talk
Subject: Draft requirements document for enhanced EPICS motor support
Folks,
I have created a straw-man requirements document for enhanced EPICS motor control in the new EPICS-motor-wg project on github.
https://github.com/EPICS-motor-wg/discussions/blob/master/documents/Requirements.md
If interested please take a look. You can make contributions via the pull request mechanism on github.
- Draft requirements document for enhanced EPICS motor support Mark Rivers
- RE: Draft requirements document for enhanced EPICS motor support Mooney, Tim M.
Re: Draft requirements document for enhanced EPICS motor support Torsten Bögershausen
RE: Draft requirements document for enhanced EPICS motor support Mark Rivers
<2015>
2025
2026
RE: Draft requirements document for enhanced EPICS motor support Mark Clift
<2015>
2025
2026
