1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: aravisGigE areaDetector with Basler camera
Date: Thu, 4 Jun 2015 13:25:03 +0000
I’m trying to use aravisGigE to drive a Basler acA1920 ethernet camera with areaDetector. I’m following the instructions at https://github.com/areaDetector/aravisGigE to add a new camera. As detailed below, I can get an XML file from the camera, but makeDbAndEdl.py is not parsing this file. The XML file is large, but the failure seems to be right at the beginning. Am I doing something stupid, or is the Basler camera incompatible with aravisGigE?
FIRST TWO LINES OF XML FILE:
Basler-21630837
<RegisterDescription xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.genicam.org/GenApi/Version_1_0" xsi:schemaLocation="http://www.genicam.org/GenApi/Version_1_0 http://www.genicam.org/GenApi/GenApiSchema_Version_1_0.xsd" MajorVersion="3" MinorVersion="7" ModelName="GigECamera" ProductGuid="1F3C6A72-7842-4edd-9130-E2E90A2058BA" SchemaMajorVersion="1" SchemaMinorVersion="0" SchemaSubMinorVersion="1" StandardNameSpace="GEV" SubMinorVersion="0" ToolTip="Basler generic GigEVision camera interface" VendorName="Basler" VersionGuid="6512A424-1B05-4C68-99D6-91F0E31857CD">
  <Category Name="Root" NameSpace="Standard">
ATTEMPT TO ADD NEW CAMERA:
[root@video aravisGigE]# Basler_acA1920.xmltoolbin/linux-x86_64/arv-tool-0.4m
Basler-21630837
[root@video aravisGigE]# bin/linux-x86_64/arv-tool-0.4 -n "Basler-21630837" genicam > Basler_acA1920.xml
[root@video aravisGigE]# aravisGigEApp/src/makeDbAndEdl.py Basler_acA1920.xml Basler_acA
Traceback (most recent call last):
  File "aravisGigEApp/src/makeDbAndEdl.py", line 22, in <module>
    xml_root = parse(args[0])
  File "/usr/lib64/python2.7/xml/dom/minidom.py", line 1921, in parse
    return expatbuilder.parse(file)
  File "/usr/lib64/python2.7/xml/dom/expatbuilder.py", line 924, in parse
    result = builder.parseFile(fp)
  File "/usr/lib64/python2.7/xml/dom/expatbuilder.py", line 207, in parseFile
    parser.Parse(buffer, 0)
xml.parsers.expat.ExpatError: syntax error: line 1, column 0
Eliot Specht                        Voice: (865)574-7682
Oak Ridge National Laboratory       FAX:   (865)574-4913
P.O. Box 2008, MS 6064
Oak Ridge, TN 37831-6064
Re: aravisGigE areaDetector with Basler camera Pete Jemian
Prev: RE: Draft requirements document for enhanced EPICS motor support Mark Rivers
Next: Re: aravisGigE areaDetector with Basler camera Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Using devIocStats under dynamic epics build. Alireza Panna
