1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS base-3.14.12.5 installation error
To: Alex George <[email protected]>
Date: Mon, 22 Jun 2015 00:47:15 +0000
Hi Alex,
I've seen issues like that on Windows before, check the file permissions on the installed files and on the various directories above it. That seems to be a common cause of this kind of thing, for which you might have to add some permission to the top level directory to have the build work properly.
HTH,
- Andrew
Sent from my iPad
> On Jun 21, 2015, at 5:19 PM, Alex George <[email protected]> wrote:
> Hi,
> I'm attempting to compile EPICS base 3.14.12.5 onto my Windows 8 laptop.
> However, during compilation I receive the following error:
> perl ../../../bin/windows-x64/registerRecordDeviceDriver.pl ../O.Common/softIoc.
> dbd softIoc_registerRecordDeviceDriver C:/epics/base-3.14.12.5 > softIoc.tmp
> Can't open perl script "../../../bin/windows-x64/registerRecordDeviceDriver.pl":
>  No such file or directory
> make[3]: *** [softIoc_registerRecordDeviceDriver.cpp] Error 2
> make[3]: Leaving directory `C:/epics/base-3.14.12.5/src/softIoc/O.windows-x64'
> make[2]: *** [install.windows-x64] Error 2
> make[2]: Leaving directory `C:/epics/base-3.14.12.5/src/softIoc'
> make[1]: *** [softIoc.install] Error 2
> make[1]: Leaving directory `C:/epics/base-3.14.12.5/src'
> make: *** [src.install] Error 2
> Although 'registerRecordDeviceDriver.pl' is not being recognized, I've confirmed that the file does exist and the path is consistent.
> I've tried the following to no success:
> - using Strawberry Perl and ActivePerl
> - attempting a static build vs a dynamic build
> Any direction is appreciated!
> Alex George
> Postbaccalaureate Fellow
> Imaging Physics Lab
> NHLBI, NIH
> Phone: (301) 741-0847
EPICS base-3.14.12.5 installation error Alex George
Prev: EPICS base-3.14.12.5 installation error Alex George
Next: EPICS support for Extrel Mass Spectrometers Heinz Junkes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS base-3.14.12.5 installation error Andrew Johnson
