1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Heads-Up: CA Gateway drops 3.13 compatibility
To: EPICS Tech-Talk <[email protected]>
Date: Mon, 22 Jun 2015 10:45:48 +0200
All,
To reduce some considerable amount of #ifdef'd code (that has been largely untested for years) I am planning to remove the CA Gateway's 3.13 compatibility features. That means: future versions of the CA Gateway will not compile against EPICS Base 3.13 anymore. Note that the Channel Access protocol connects across even larger version gaps - a Gateway compiled against 3.14 or 3.15 will continue to work perfectly with IOCs or clients using EPICS 3.13.
Anyone here to whom this will pose an unsurpassable difficulty should speak up now (and be ready to take responsibility) or forever hold your peace.
Thanks for your cooperation,
~Ralph
Prev: EPICS support for Extrel Mass Spectrometers Heinz Junkes
Next: Re: EPICS base-3.14.12.5 installation error Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: multi-channel analog i/p Stephen Paul
