1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: autosave ---Data coverage
To: l123173 <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 30 Jun 2015 15:22:31 +0000
Hi Li,
I think you want an archiver.  You want not only the current value of a PV to be saved, but all values.  You probably also want the times when the value changed.  Yes?  If so, autosave is not the tool you want.  I haven't used or deployed an archiver, but others on this list are expert at it.  There are several solutions.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of l123173 [[email protected]]
Sent: Tuesday, June 30, 2015 9:59 AM
To: [email protected]
Subject: autosave ---Data coverage
Hi everyone,
      I have a little question about the autosave module. (RH 6.0, synApp5-6, autosave4-8)
      I started the xxx module and autosave module worked well, but the newest data would be covered, I want all number of the data(pv) be saved.
      I did not use the array, the data is just a numble.
      Could you give me some advice?
Thank you,
Li xing
autosave ---Data coverage l123173
Prev: autosave ---Data coverage l123173
Next: Re: epicsExit (); function exits the IOC but the Linux console requires a resest to be operative Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: epicsScanDouble behavior change in R3.15 Priller, John
