It looks like those records are not loaded.
- Send the output o
dbl
At the iocsh prompt
- Send the complete output when the IOC starts.
Sent from my iPhone
> On Jul 2, 2015, at 4:48 PM, S. Banerian <[email protected]> wrote:
> I'm setting up an IOC to read/write to an RF amp that communicates over
> the net apropos of stream device.
> For single value send/receives, I've not encountered any thing serious.
> However, there are a few parameters that we need to read back that come
> from a single query.
> background:
> you sent it a string query, it sends back a reply.
> what is sent over telnet:
> /DEV659/DEMODS/0/SAMPLE: ?
> what is received in reply:
> /DEV659/DEMODS/0/SAMPLE: TS=2938752.083168305, X=0.0000022024,
> Y=-0.0000035017, F=25900801.32071, Phi=2.45412
> (all on one line, no CR/LF)
> With reference to
> http://epics.web.psi.ch/software/streamdevice/doc/tipsandtricks.html#readmany
> (part C):
> read_AB {out "GET A,B"; in "A=%f, B=%(\$1)f";}
> my protocol file has:
> readts{
> out "/DEV659/DEMODS/0/SAMPLE: ?";
> in "/DEV659/DEMODS/0/SAMPLE: TS=%f, X=%(\$1)f, Y=%(\$2)f,
> F=%(\$3)f, Phi=%(\$4)f";
> and the db file, with substitution in st.cmd DEVICE=DEMOD
> record(ai, "$(DEVICE):ts") {
> field(SCAN, "1 second")
> field(DTYP, "stream")
> field(INP, "@zi.proto
> readts($(DEVICE):x,$(DEVICE):y,$(DEVICE):f,$(DEVICE):phi) zi")
> record(ai, "$(DEVICE):x") {
> record(ai, "$(DEVICE):y") {
> record(ai, "$(DEVICE):f") {
> record(ai, "$(DEVICE):phi") {
> IOC shell startup errors observed:
> Field 'DEMOD:x' not found
> in format string: "%(DEMOD:x)f, Y=%(DEMOD:y)f,
> F=%(DEMOD:f)f, Phi=%(DEMOD:phi)f"
> in command 'in'
> in protocol 'readts'
> while compiling protocol 'readts(DEMOD:x,DEMOD:y,DEMOD:f,DEMOD:phi)' for
> 'DEMOD:ts'
> DEMOD:ts: Protocol parse error
> I was considering trying to just read in the TS value and then ignore
> the rest of the line, then try to add in each value and ignore the rest,
> in sequence, to see if I could find the error.
> I have tried changing the protocol file, hard coding in PV names instead
> of using macros, with db modification appropriate to that, but the iocsh
> errors were observed.
> S. Banerian
> UW Clinical Cyclotron
> UW School of Medicine
> 206-598-0302
> gpg key 6642E7EE
> fingerprint = BD13 875D 2D03 5E1D 1E3B 8BF7 F4B8 63AD 6642 E7EE
- stream device - multiple values from a string S. Banerian
setting NTP time sync interval on vxWorks Zhang Yuliang
<2015>
2025
2026
RE: stream device - multiple values from a string peter.owens
<2015>
2025
2026
