1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: setting NTP time sync interval on vxWorks
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 03 Jul 2015 11:33:16 +0200
Hi Yuliang,
The NTP sync interval is a compile time constant, thus it cannot be changed at run time.
One question, though.
Your time report shows that the measured tick rate is 60.007 Hz, which is a difference of about 2 us per tick, 120 us per second, 7.2 ms per minute. Time resolution is in ticks, i.e. 16.67 ms. That means the NTP sync will skip a single tick in the counter every two or three minutes.
Why do you want to change the sync interval?
Setting it longer will make the situation worse: more than one tick will be skipped at larger intervals. Setting it shorter will increase network traffic without changing the situation much: a deviation of 7.2 ms per minute will always be corrected by skipping one tick after between two and three minutes.
Cheers,
~Ralph
On 03/07/2015 10:36, Zhang Yuliang wrote:
Hi all,
I want to know how to set the NTP time sync interval on vxWorks. The output of "NTPTime_Report 1" shows the default interval is 60 seconds:
timingMain>NTPTime_Report 1
NTP driver is synchronized with server
Syncronization interval = 60.0 seconds
Last synchronized at 2015-07-03 16:06:19.062927
OS tick rate = 60 Hz (nominal)
Measured tick rate = 60.007 Hz
NTP Server = 10.1.201.31
value = 0 = 0x0
I can modify the variable "NTPTimeSyncInterval" in file $(EPICS_BASE)\src\libCom\osi\osiNTPTime.c to change the sync interval. Is there a command can be used in ioc shell?
Best regards,
Zhang Yuliang
Re: Re: setting NTP time sync interval on vxWorks Zhang Yuliang
Prev: setting NTP time sync interval on vxWorks Zhang Yuliang
Next: RE: stream device - multiple values from a string peter.owens
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Re: setting NTP time sync interval on vxWorks Zhang Yuliang
