1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stepper Motor Controllers
To: "<[email protected]>" <[email protected]>
Date: Fri, 10 Jul 2015 15:10:23 -0500
One disadvantage of the Newport XPS controller is that the controller
requires its configuration to match the stages that are physically
connected.  If one stage is disconnected from the controller, none of
the other axes will be usable until the unused axis is reconfigured to
be a dummy axis.  For stable setups this isn't an issue.  For
frequently-changing setups this can be quite annoying.
Kevin
On 7/10/15 9:58 AM, Mark Rivers wrote:
> We have 11 Newport XPS controllers on our beam lines. In my
> experience they are much easier to configure than the Delta Tau
> units. They have a user-friendly Web interface, all parameters are in
> engineering units, etc. There is an EPICS interface to complex
> multi-axis coordinated motion with detector triggering, and lots of
> other auxiliary I/O.
> Mark
Re: Stepper Motor Controllers Mark Rivers
Stepper Motor Controllers Mark Davis
Prev: caQtDM related questions Alireza Panna
Next: Re: Stepper Motor Controllers Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stepper Motor Controllers Mark Rivers
