1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stepper Motor Controllers
To: [email protected]
Date: Tue, 14 Jul 2015 11:20:38 -0400
Hi Mark,
As is probably true with most labs, we do indeed have some VME stuff, but for the main control system we have been slowly eliminating VME when we can. The hardware is just so much more expensive than using fairly generic rack-mount PCs running Linux and using Ethernet (directly or via Ethernet-to-serial/GPIB/whatever adapters) to talk to stand-alone devices.
So far the list of requirements I have compiled from searching through the mass of documents regarding the new FRIB infrastructure has not turned up anything particularly demanding, but of course many details are still in flux so I am trying to be "generous" in terms of reading between the lines and extrapolating a bit regarding what is likely to be required once the details start firming up. As long as some particular feature doesn't result in a drastic increase in price, a solution that does a bit more than meet the minimum requirements will undoubtedly save us money in the long run.
This is what I have come up with so far that is related to the choice of controller:
- Complex coordinated motion (2 axes minimum for insuring smooth movement of things like pairs of jaws) - Fault outputs (so an external PLCs can manage the state of a group of related devices)
   - Support for 3 limit switches (min, max, and home/reference positions)
   - Support for on-the-fly scans:
- At minimum, the ability to generate pulses for each axis based on current position of each axis
        - Ability to capture/buffer the data itself would be a plus
- Support for a variety of analog or digital encoders. Currently specified types include:
        - Linear motion potentiometers
        - Rotary Sine/Cosine potentiometers
        - Digital (optical, rotary, relative, absolute?)
- Support for local control box (i.e. continue to track/report position, disable movement if limit switch activated, etc)
   - Prefer models that do not require external motor drivers
   - Ethernet interface
   - Firmware version readable by control system
   - Ability to update firmware remotely
Regarding closed loop mode: While I can imagine circumstances where you might want to disable it, I would think that any controller that supports an encoder would also provide a closed loop mode. Is that not so? I would think there would be little advantage to supporting an encoder if it couldn't be used directly by the controller during movements (i.e. isn't this question the SAME as "Does it support a position encoder"?)
Regarding price/axis: I haven been given a specific $ amount on this yet, but we have been using the Parker GT6K single-axis controllers which are around $3000 each, and I have been assuming that most newer multi-axis solutions will be significantly less expensive.
On 7/10/2015 1:34 PM, Mark Rivers wrote:
Hi Mark,
I think that to make a useful recommendation on this it would help to know more about the requirements.
- How many axes?
- Do you have VME infrastructure already available?
- Do you plan to use encoders?
- How important is cost per axis?
- What are the performance requirements?
   - Microstepping?
   - Coordinated motion?
   - Closed loop feedback if you have encoders?
For example, Tim's suggestion of the MAXv would be best suited if you already have VME, and don't need closed loop encoder feedback or very fine microstepping.  The XPS or Delta Tau, on the other hand can do closed loop feedback, very fine microstepping, and coordinated motion.
If you only have a few axes and no VME there are solutions like the ACS MCB-4B that are about $400 per axis, while many other solutions are $1,000-$1,500 per axis.
From: [email protected] [[email protected]] on behalf of Mark Davis [[email protected]]
Sent: Friday, July 10, 2015 9:52 AM
Subject: Stepper Motor Controllers
Hi all,
I am currently in the process of reviewing the capabilities of DC
Stepper Motor Controller/Drivers and was wondering what other labs are
currently using and what they like/dislike about them.
I have read Matthew Pearson's summary from 8/2010 regarding the Delta
Tau VME Turbo PMAC 2, Delta Tau Geobrick LVM, Newport XPS.
  From his description, I assume the Delta Tau Geobrick LV is a
significantly different device (at least physically) than the Geobrick
LVM.  At the very least LV is MUCH smaller (15.4" x 4" x 7.2").  It is
still a PMAC2 based controller, but they make a point of the elimination
of analog signaling:
       "The absence of analog signals – required for typical motion
controller/drive interfacing – enables higher gains, better overall
performance and tighter integration, while significantly decreasing
costs and setup time."
This may explain how they managed to make it so much smaller the the LVM
model (which, as near as I can tell, they no longer make).  It might
also help avoid the noise problem that Matthew mentioned regarding the
LVM model.
  From reading various other Tech-talk postings my impression is that the
Delta Tau PMAC controllers are very capable, but complex and require a
lot of effort to get set up correctly.  However, that may be mitigated
to some extent by using the synApps tpmac module (and BNL's page
regarding setup and configuration).
What other controllers are being used?  What are the advantages,
disadvantages, and problems that have been encountered?
Mark Davis
NSCL/FRIB
[email protected]
Re: Stepper Motor Controllers Pete Jemian
Re: Stepper Motor Controllers Torsten Bögershausen
Stepper Motor Controllers Mark Davis
RE: Stepper Motor Controllers Mark Rivers
Prev: RE: Conversion to Hexadecimal Mark Rivers
Next: Re: Conversion to Hexadecimal Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Stepper Motor Controllers Mark Rivers
Next: Re: Stepper Motor Controllers Pete Jemian
