1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: streamdevice mbbiDirect mask
To: tech-talk <[email protected]>
Date: Sun, 19 Jul 2015 12:25:03 +0800
hi,
in the website of streamdevice, it says:
Normal Operation
Depending on the format type, different record fields are used for output and input. The variable x stands for the written or read value.
DOUBLE format (e.g. %f):
Not allowed.
LONG format (e.g. %i):
If MASK==0 (because NOBT is not set):
Output: x=VAL
Input: VAL=x
If MASK!=0:
Output: x=RVAL&MASK
Input: RVAL=x&MASK
MASK is initialized to NOBT 1-bits shifted left by SHFT.
ENUM format (e.g. %{):
Not allowed.
STRING format (e.g. %s):
Not allowed.
In my case, I use mbbiDirect and get a value as 0x29 (b"0010,1001") in VAL field. If I want to mask it with a value 0xC1(b"1100,0001"), how to set NOBT/SHFT field?
Thanks a lot in advance.
Best wishes
Geyang 2015-07-19
RE: streamdevice mbbiDirect mask Mark Rivers
Prev: Re: xspress3 Matt Newville
Next: RE: streamdevice mbbiDirect mask Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: xspress3 Adam Bark
