Hello,
I have created a device support to fetch data from waveform record and this waveform record gets input from asyn record. When I run ioc I get error as Segmentation fault(core dumped). kindly suggest how to resolve this error. [srk@srk VME]$ cd iocBoot/iocmyExample/ [srk@srk iocmyExample]$ ./st.cmd #!../../bin/linux-x86/myExample ## You may have to change myExample to something else ## everywhere it appears in this file < envPaths epicsEnvSet("ARCH","linux-x86") epicsEnvSet("IOC","iocmyExample") epicsEnvSet("TOP","/home/srk/VME") epicsEnvSet("ASYN","/home/srk/EPICS/R3.14.12.1/synApps_5_7/support/asyn-4-21") epicsEnvSet("CALC","/home/srk/EPICS/R3.14.12.1/synApps_5_7/support/calc-3-2") epicsEnvSet("EPICS_BASE","/home/srk/EPICS/R3.14.12.1/base") cd /home/srk/VME ## Register all support components dbLoadDatabase "dbd/myExample.dbd" myExample_registerRecordDeviceDriver pdbbase ## initialize port for test serial drvAsynSerialPortConfigure("L2","/dev/ttyS0",0,0,0) asynSetOption("L2",-1,"baud","19200") asynSetOption("L2",-1,"bits","8") asynSetOption("L2",-1,"parity","none") asynSetOption("L2",-1,"stop","1") asynSetOption("L2",-1,"clocal","Y") ## Load record instances dbLoadTemplate "db/userHost.substitutions" dbLoadRecords "db/dbSubExample.db", "user=srkHost" dbLoadRecords "db/project.db" Can't set "wafData.INP" to "vmeInput.BINP" Error at or before ")" in file "db/project.db" line 29 ## Set this to see messages from mySub #var mySubDebug 1 ## Run this to trace the stages of iocInit #traceIocInit cd /home/srk/VME/iocBoot/iocmyExample iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.1 $Date: Tue 2011-04-26 15:36:19 -0500$ ## EPICS Base built Oct 7 2014 ############################################################################ iocRun: All initialization complete ## Start any sequence programs #seq sncExample, "user=srkHost" ../online_notify.c: CA beacon (send to "127.0.0.1:5065") error was "Connection refused" Value=5 ../online_notify.c: CA beacon (send to "127.0.0.1:5065") error was "Connection refused" Value=5 epics> Value=5 Value=5 Value=5 Value=5 ../online_notify.c: CA beacon (send to "127.0.0.1:5065") error was "Connection refused" Value=5 Value=5 Value=5 Value=5 Value=5 Value=5 Value=5 Value=5 Value=5 Value=5 Segmentation fault (core dumped) [srk@srk iocmyExample]$ db file is as follows: record(asyn, vmeInput) { field(SCAN, "1 second") field(DTYP, "asynRecordDevice") field(FLNK, "wafData") field(PORT, "L2") field(TMOD, "Write/Read") field(IFACE, "asynOctet") field(AOUT, "ST03@U#PKT01!") field(OFMT, "ASCII") field(NRRD, "80") field(IFMT, "Hybrid") field(BAUD, "19200") field(PRTY, "None") field(DBIT, "8") field(SBIT, "1") field(CNCT, "Connect") field(ENBL, "Enable") } record(waveform, wafData) { field(SCAN, "Passive") field(DTYP, "wafsupport") field(INP, "vmeInput.BINP") field(NELM, "72") field(FTVL, "CHAR") field(FLNK, "forwardlink") } record(ai, analogInput) { field(SCAN, ".1 second") field(DTYP, "aisupport") } DEVICE SUPPORT I have created is as follows: #include <stdio.h> #include <string.h> #include <stddef.h> #include <math.h> #include <stdlib.h> #include "alarm.h" #include "cvtTable.h" #include "dbDefs.h" #include "dbAccess.h" #include "recGbl.h" #include "recSup.h" #include "devSup.h" #include "link.h" #include "aiRecord.h" #include "waveformRecord.h" #include "epicsExport.h" //static int v=1; static int v=2,y=3,z; //long n; //char myptr[72]; //struct DBADDR *paddr; static long read_aiValue(); //static long read_aiValue1(); static long read_waveform(); // structure for ai struct { long number; DEVSUPFUN report; DEVSUPFUN init; DEVSUPFUN init_record; DEVSUPFUN get_ioint_info; DEVSUPFUN read_aiValue; DEVSUPFUN special_linconv; } devmyai = { 6, NULL, NULL, NULL, NULL, read_aiValue, NULL}; epicsExportAddress(dset,devmyai); //------------STRUCTURE FOR WAVEFORM--------- struct { long number; DEVSUPFUN report; DEVSUPFUN init; DEVSUPFUN init_record; DEVSUPFUN get_ioint_info; DEVSUPFUN read_waveform; } devmywaveform = { 5, NULL, NULL, NULL, NULL, read_waveform}; epicsExportAddress(dset,devmywaveform); static long read_aiValue(pai) struct aiRecord *pai; { //static int v=2,y=3,z; pai->val=(v+y); z=(v+y); printf("\nValue=%d\n",z); return(2); } static long read_waveform(pwaf) struct waveformRecord *pwaf; { long int n; char myptr[100]; struct dbAddr *paddr; //long status,n; n = pwaf->nelm; paddr = dbGetPdbAddrFromLink(&pwaf->inp); dbGet(paddr,pwaf->ftvl,(void *)myptr,0,&n,NULL); //printf("\nstatus=%s\n",myptr); return 0; } Please help me with this error. Thanks in advance
| ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
