1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: seq_snc.h: file not found
To: [email protected]
Date: Mon, 3 Aug 2015 02:47:09 +0500
Hi
I converted my test.st file to test.c file using snc but found following error while compiling the c file.
cc test.c -o test.o
test.c:7:21: error: seq_snc.h: No such file or directory
test.st:15: error: expected ‘)’ before ‘seqg_env’
test.st:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_event_volt_check_0_light_off’
test.st:22: error: expected ‘)’ before ‘seqg_env’
test.st:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_event_volt_check_0_light_on’
test.st:29: error: expected ‘)’ before ‘seqg_env’
test.st:32: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_chans’
test.st:39: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_mask_volt_check_0_light_off’
test.st:42: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_mask_volt_check_0_light_on’
test.st:47: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_states_volt_check’
test.st:69: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_statesets’
test.st:78: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘test’
test.st:96:25: error: epicsExport.h: No such file or directory
test.st: In function ‘testRegistrar’:
test.st:99: error: ‘test’ undeclared (first use in this function)
test.st:99: error: (Each undeclared identifier is reported only once
test.st:99: error: for each function it appears in.)
test.st: At top level:
test.st:101: warning: data definition has no type or storage class
test.st:101: warning: parameter names (without types) in function declaration
Any suggestion how to include the seq_snc.h in order to remove the problem. I can see seq_snl.h file in my include directory of seq-2.2.2
regards,
Tasaddaq
Re: seq_snc.h: file not found Mark Rivers
Prev: Re: draw ROI in imageJ and send to epics Roehrig, Christian
Next: Re: seq_snc.h: file not found Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
