1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: NDTransform Image Delay
To: <[email protected]>, <[email protected]>
Date: Thu, 6 Aug 2015 12:08:31 +0000
Hi Mike,
I suspect you will also see your queue build up, and I presume the depth of the image queue is about 50 images, and this is what is giving the 5 second delay. If you want to see an image without delay, you need a short queue and have to accept the dropped frames.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: 06 August 2015 11:53
To: Slade, Michael (STFC,RAL,AST); [email protected]
Hi Mike,
What version of areaDetector are you using? In areaDetector 1-NN this plugin performed rather unimpressively. However in areaDetector 2 (ADCore); Chris Roehrig did an “Extensive re-write” (May 2014) which increased performance e19490e.
Cheers,
Ulrik
Sent: 06 August 2015 11:21
To: [email protected]
Subject: NDTransform Image Delay
I am using the NDTransform plugin for AreaDetector, so I am able to rotate images acquired by a camera. This works completely fine, unless the acquire time of the camera is 0.1 or smaller (reading in images at 10Hz or faster).
At these rates, there is a delay applied to the camera, i.e, if the camera sees something different, the image the AreaDetector software returns won’t show the change for around 5 seconds. I assumed that the rotation was just taking a long time to process, but the overlays I apply after the transformation have no delay at all. I have also noticed that when this delay occurs, the ‘DroppedArrays’ PV for the NDTransform plugin increases.
Is there a way to stop this delay from happening?
Mike
NDTransform Image Delay michael.slade
RE: NDTransform Image Delay ulrik.pedersen
Prev: RE: NDTransform Image Delay ulrik.pedersen
Next: Re: NDTransform Image Delay Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
