1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: To write data to VDCT from device support
To: [email protected]
Date: Fri, 7 Aug 2015 15:14:07 +0530
Hello,
I have created following device support. Now what I want is to write values of a array(as per following code c2 array) to a waveform record(PV name: optoRead) in VDCT
#include <stdio.h>
#include <string.h>
#include <stddef.h>
#include <math.h>
#include <stdlib.h>
#include "alarm.h"
#include "cvtTable.h"
#include "dbDefs.h"
#include "dbAccess.h"
#include "recGbl.h"
#include "recSup.h"
#include "devSup.h"
#include "link.h"
#include "aiRecord.h"
#include "waveformRecord.h"
#include "epicsExport.h"
int i;
unsigned short c1[50],c2[10];
static long read_waveform();
static long read_wafopto();
//------------STRUCTURE FOR WAVEFORM---------
struct
long   number;
DEVSUPFUN report;
DEVSUPFUN init;
DEVSUPFUN init_record;
DEVSUPFUN get_ioint_info;
DEVSUPFUN read_waveform;
devmywaveform = {
      5,
      NULL,
      NULL,
              NULL,
      NULL,
              read_waveform};
epicsExportAddress(dset,devmywaveform);
//------------STRUCTURE FOR WAVEFORM to get opto-reading---------
struct
long   number;
DEVSUPFUN report;
DEVSUPFUN init;
DEVSUPFUN read_wafopto;
devwafopto = {
      5,
      NULL,
      NULL,
              NULL,
      NULL,
              read_wafopto};
epicsExportAddress(dset,devwafopto);
//-----------------CODE-----------------//
static long read_waveform(pwaf)
struct waveformRecord *pwaf;
//int i;
long int n;
unsigned short myptr[100];
struct dbAddr *paddr;
//unsigned short c1[50],c2[10];
n = pwaf->nelm;
paddr = dbGetPdbAddrFromLink(&pwaf->inp);
dbGet(paddr,pwaf->ftvl,(void *)myptr,0,&n,NULL);
for(i=0;i<=71;i++)
printf("\ndata=%x\n",myptr[i]);
for(i=0;i<36;i++)
 if(myptr[i+36]==143)
c1[i]=myptr[i]-50;
  else
      c1[i]=myptr[i];
for(i=0;i<36;i++)
printf("\ndata1=%u %x\n",c1[i],c1[i]);
for(i=0;i<=4;i++)
c2[i]=c1[i+4];
for(i=0;i<=4;i++)
printf("\ndata2=%u",c2[i]);
return(2);
          //---DEVICE SUPPORT TO VDCT---
static long read_wafopto(popto)
struct waveformRecord *popto;
//char *optoRead[10];
long int n;
//paddr = dbGetPdbAddrFromLink(&inp->popto);
//dbPut(paddr,popto->ftvl,(void *)c2,&n);
n = popto->nelm;
dbNameToAddr("optoRead.VAL",paddr);
dbPut(paddr,popto->ftvl,(void *)c2,n);
//popto->val=c2;
return(2);
DB FILE:
record(waveform, optoRead) {
  field(SCAN, "Passive")
  field(NELM, "4")
  field(FTVL, "USHORT")
  field(DTYP, "wafoptosupport")
I want to write value of c2 array in waveform record in VDCT. On doing "caget" I get following output:
 caget optoRead
optoRead 4 3 0 0 0
Output should be:
optoRead 4 127 255 0 0
When I do "make" i do not get any error but on doing "make clean install" I get following warning:
../aiDevsup.c: In function ‘read_wafopto’:
../aiDevsup.c:274:14: warning: ‘paddr’ is used uninitialized in this function [-Wuninitialized]
Please suggest how to resolve this warning .Also suggest is there any other way to write this data in VDCT or is it possible to use any other record other than waveform. My ultimate aim is to get this data in VDCT and  convert it in binary.
RE: To write data to VDCT from device support Mooney, Tim M.
Prev: Data Archiver info22
Next: RE: Data Archiver Pierrick M Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Data Archiver Jeong Han Lee
Next: RE: To write data to VDCT from device support Mooney, Tim M.
