1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Periodic record
To: [email protected]
Date: Mon, 10 Aug 2015 12:12:36 -1000
On 08/10/15 11:36, Andrew Johnson wrote:
Hi Mike,
On 08/10/2015 03:40 PM, [email protected] wrote:
I have a question. The limit for a periodic record like calc example is
10 seconds. I want to create a periodic record to change a value every
hour. Is there a possibility? And how can I use a GUI to set parameters
like voltage?
There are various alternative ways to do what you want, a calcout record
decrementing a counter would probably be the simplest example.
A sequence record with a long delay?
Maren
Periodic record info22
Re: Periodic record Andrew Johnson
Prev: Re: Periodic record Andrew Johnson
Next: Post Job Advertisement Esposito, Peter J
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
