1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS base-3.15.2 compilation error for VS Express 2015 on Windows 10
To: <[email protected]>
Date: Thu, 20 Aug 2015 10:06:14 -0500
Mark's answer about the needed change to base/src/libCom/osi/os/WIN32/osdTime.h is correct. As for the second problem, I had to move from VS 2015 Express to VS 2015 Community because the Express edition uses a cross-compiler to create the 64 bit binaries while the Community version has a native 64bit compiler. This got me past the array size limit.
On 08/19/2015 11:43 PM, Chu, Paul wrote:
Hi all,
When I tried to compile EPICS base 3.15.2 on Windows 10 with MS Visual Studio Express 2015, I got the following error. I tried on VS Express 2010 (with Windows SDK), 2012 and 2013 for Windows 10 and all went through without any problem (for both win32-x86 and windows-x64). VS Express 2015 is the only one with trouble. The first error seems to be caused by ‘timespec’ redefined (see below). After I commented out the ‘timespec’ def in the code, there’s another array size exceeds limit error…
I was wondering if anybody else successfully compiled the code with VS Express 2015.
Paul
cl -EHsc -GR                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_C
RT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355        -MD -DEPICS_BUILD_DL
L -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler
/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/o
s/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../
../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtF
ast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../s
rc/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../..
/src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../..
/../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
-I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/mi
sc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ri
ng -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCo
m/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/
compiler/msvc -I../../../include/os/WIN32 -I../../../include         -c ../../..
/src/libCom/fdmgr/fdmgr.cpp
fdmgr.cpp
../../../src/libCom/osi/os/WIN32\osdTime.h(21): error C2011: 'timespec': 'struct
' type redefinition
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\time.h(39): not
e: see declaration of 'timespec'
make[3]: *** [fdmgr.obj] Error 2
make[3]: Leaving directory `c:/epics/base-3.15.2/src/libCom/O.win32-x86'
make[2]: *** [install.win32-x86] Error 2
make[2]: Leaving directory `c:/epics/base-3.15.2/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `c:/epics/base-3.15.2/src'
make: *** [src.install] Error 2
make: Leaving directory `c:/epics/base-3.15.2'
Sent from Mail for Windows 10
Re: EPICS base-3.15.2 compilation error for VS Express 2015 on Windows 10 Andrew Johnson
EPICS base-3.15.2 compilation error for VS Express 2015 on Windows 10 Chu, Paul
Prev: RE: Fast, reliable remote I/O in 2015 Mark Clift
Next: RE: EPICS base-3.15.2 compilation error for VS Express 2015 on Windows 10 Chu, Paul
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS base-3.15.2 compilation error for VS Express 2015 on Windows 10 Mark Rivers
Next: Re: EPICS base-3.15.2 compilation error for VS Express 2015 on Windows 10 Andrew Johnson
