1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Records for slow control
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 26 Aug 2015 11:56:27 +0200
On 26/08/2015 11:39, [email protected] wrote:
Hello,
I want to set a value like 200 ampere and increase the current value slowly but how?
I have a timer-record with a PROC field with the option "transition to zero". A second record increase the value every time. Is it possible to create records like this:
• Calcout1 timer: scan every second from 1 to 10
• -» then process Calcout2 (via PROC field, without SCAN field) from 1 to 3
• Calcout2 have to wait, process Calcout1 again...
In the ao record that is setting your value, set the field SCAN to "1 second" (or how often you want to "slowly" update) and the field OROC to the step size that you want to the value to change every time (e.g. 0.1).
No other records needed.
Now, when you write a value like 200 to that record, the output will step up by 0.1 every second. (Or whatever step size and update rate you configured.)
Hope this helps,
~Ralph
AW: Records for slow control info22
Re: Records for slow control info22
Prev: Re: Records for slow control info22
Next: AW: Records for slow control info22
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
