1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: css compile error
To: [email protected]
Date: Mon, 7 Sep 2015 22:44:37 +0800 (CST)
Hi Kay,
         When I compile the CSS source code according your cssbook, I met some problems, could you please help me?
       My environment:  Scientifc Linux 6(32), the latest eclipse, JAVA and CSS source code.
I input these command:   cd cs-studio-thirdparty;    mvn clean verify
P.S.  During the process, I can always get access to the website.
The following is the message:
[INFO] Reactor Summary:
[INFO]
[INFO] thirdparty ......................................... SUCCESS [  0.105 s]
[INFO] thirdparty-plugins ................................. SUCCESS [  0.004 s]
[INFO] org.csstudio.platform.libs.jersey .................. FAILURE [  0.260 s]
[INFO] edu.msu.nscl.olog.api .............................. SKIPPED
[INFO] gov.bnl.channelfinder.api .......................... SKIPPED
[INFO] gov.bnl.unitconversion ............................. SKIPPED
[INFO] org.csstudio.platform.libs.easymock ................ SKIPPED
[INFO] org.csstudio.platform.libs.hibernate ............... SKIPPED
[INFO] org.csstudio.platform.libs.jdbc .................... SKIPPED
[INFO] org.csstudio.platform.libs.jfreechart .............. SKIPPED
[INFO] org.csstudio.platform.libs.jmock ................... SKIPPED
[INFO] org.csstudio.platform.libs.jms ..................... SKIPPED
[INFO] org.csstudio.platform.libs.tine .................... SKIPPED
[INFO] org.eclipse.nebula.widgets.grid .................... SKIPPED
[INFO] org.eclipse.nebula.jface.gridviewer ................ SKIPPED
[INFO] gov.bnl.shiftClient ................................ SKIPPED
[INFO] thirdparty-features ................................ SKIPPED
[INFO] org.csstudio.thirdparty.all.feature ................ SKIPPED
[INFO] thirdparty-repository .............................. SKIPPED
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 01:01 min
[INFO] Finished at: 2015-09-08T06:15:37+08:00
[INFO] Final Memory: 98M/445M
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-packaging-plugin:0.22.0:build-qualifier (default-build-qualifier) on project org.csstudio.platform.libs.jersey: No git repository found searching upwards from /home/lyx/forepics/cs-studio-thirdparty-master/plugins/org.csstudio.platform.libs.jersey -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR]   mvn <goals> -rf :org.csstudio.platform.libs.jersey
Best wishes,
Li Xing
Prev: Scientific Software Developer - Fast Sample Environment to ESS in Copenhagen, Denmark Kristina Anderberg
Next: building labCA on base 3.15.2, missing tsDefs.h Gierman, Stephen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CSS compile error l123173
Next: Virtual Circuit Disconnect Warning Deepika Thakur
