Hi Stephen,
The tsDefs.h header was removed from Base between the 3.14 and 3.15 release series, it gave access to some routines which were replaced early in the 3.14 series with a new API, the epicsTime routines and the generalTime facility. If you don't have the C programming skills to make the necessary changes to the C source yourself you should ask the labCA maintainer whether they have a version ported to EPICS 3.15.2. The changes shouldn't take an experienced C developer very long to make, often the tsDefs.h routines were just used to convert time stamps into a string representation, for which there is now an EPICS version of strftime() that can be used instead.
If you want to try making the fix yourself, start by removing the #include "tsDefs.h" line from the multiEzca.h file and running make again to see what that breaks. You might want to try replacing it with #include "epicsTime.h" as well. Be sure to keep any follow-up conversation here on tech-talk since there are many people here who can help.
- Andrew
Sent from my iPad
> On Sep 7, 2015, at 6:19 PM, Gierman, Stephen <[email protected]> wrote:
> Hi,
> I'm building labCA (version 3.4.2) on base-3.15.2 for 64-bit windows. The build fails in the 'glue' directory when it cannot find the include file 'tsDefs.h'. Indeed, I do not find tsDefs.h in base-3.15.2, but I do find it in base-3.14.12.2, though it seems to be deprecated there. Here are the last few lines of the build:
> cl -EHsc -GR -DMATLAB_APP -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -I../../../../../base/include/compiler/msvc -I../../../../../base/include/os/WIN32 -I../../../../../base/include -I../../ezca -IC:\matlab\R2015a/extern/include -c ../ini.cc
> ini.cc
> ..\multiEzca.h(32) : fatal error C1083: Cannot open include file: 'tsDefs.h': No such file or directory
> make[2]: Leaving directory `C:/epics/R3.15.2/extensions/src/labca_3_4_2/glue/O.windows-x64'
> make[1]: Leaving directory `C:/epics/R3.15.2/extensions/src/labca_3_4_2/glue'
> I'm not sure what to do next ...
> Steve Gierman
- RE: building labCA on base 3.15.2, missing tsDefs.h Gierman, Stephen
- building labCA on base 3.15.2, missing tsDefs.h Gierman, Stephen
store data to hard disk l123173
<2015>
2025
2026
<2015>
2025
2026
