1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Unable to build support modules on Windows, with base 3.15.2
To: "'Heesterman, Peter J'" <[email protected]>, "EPICS Tech-Talk ([email protected])" <[email protected]>
Date: Mon, 14 Sep 2015 18:54:22 +0000
Hi Peter,
I just tested building base 3.15.2 on windows-x64, and then building the support modules (seq, asyn, autosave, etc.).  It worked fine for me, I did not get the errors you did.
What version of perl are you using?
I am using ActivePerl 5.14.2.
C:\EPICS>perl --version
This is perl 5, version 14, subversion 2 (v5.14.2) built for MSWin32-x64-multi-thread
(with 1 registered patch, see perl -V for more detail)
Copyright 1987-2011, Larry Wall
Binary build 1402 [295342] provided by ActiveState http://www.ActiveState.com
Built Oct  7 2011 15:19:36
From: [email protected] [mailto:[email protected]] On Behalf Of Heesterman, Peter J
Sent: Monday, September 14, 2015 9:24 AM
To: EPICS Tech-Talk ([email protected])
Subject: Unable to build support modules on Windows, with base 3.15.2
I just downloaded EPICS base 3.15.2, superseding previous 3.15.1.
I am experiencing a problem building any of the support modules, while using the make file build.
(There is no problem building base 3.15.2 itself, however.)
I’ve built all the same code successfully on Linux, while using 3.15.2.
See attached, these are examples when trying to build Asyn or Seq, but this applies to all modules I’ve looked at, and to different build configurations I’ve attempted.
It all built OK when using 3.15.1.
What could I be missing?
Peter.
RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Prev: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Next: Olog client login 吴煊
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
