1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Unable to build support modules on Windows, with base 3.15.2
To: "Heesterman\, Peter J" <[email protected]>
Cc: "EPICS Tech-Talk \([email protected]\)" <[email protected]>
Date: Tue, 15 Sep 2015 23:02:33 +0300
"Heesterman, Peter J" <[email protected]> writes:
> Hi,
> I just downloaded EPICS base 3.15.2, superseding previous 3.15.1.  I
> am experiencing a problem building any of the support modules, while
> using the make file build.  (There is no problem building base 3.15.2
> itself, however.)
> I've built all the same code successfully on Linux, while using
> 3.15.2.
> See attached, these are examples when trying to build Asyn or Seq, but
> this applies to all modules I've looked at, and to different build
> configurations I've attempted.  It all built OK when using 3.15.1.
> What could I be missing?
This doesn't look so good
    perl -CSD D:/EPICS/support/asyn/configure/\EPICS\base/bin/win32-x86-static/makeMakefile.pl O.win32-x86-static ../..
i.e. that "\EPICS\base" part.
I would check the contents of asyn/configure/RELEASE for definitions of
SUPPORT and EPICS_BASE or the contents of environment variables.
Jani Hakala
RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Prev: RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Next: RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
