1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: linking C-functions to state machines
To: "'kowalski-jankowalski.1986'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 6 Oct 2015 18:07:58 +0000
I have fixed your Makefile.   Here is the patch.  This version works for me.  I added testFunc.c to NAZWASupport and added NAZWASupport to sncProgram_LIBS.
corvette:example/exampleApp/NAZWASrc>diff -U3 Makefile.orig Makefile
--- Makefile.orig       2015-10-06 13:05:15.858083606 -0500
+++ Makefile    2015-10-06 13:00:00.318191828 -0500
@@ -21,14 +21,13 @@
 #NAZWA_DBD += xxx.dbd
 # Add all the support libraries needed by this IOC
-NAZWA_LIBS_DEFAULT += testFunc
+NAZWASupport_SRCS += testFunc.c
 # NAZWA_registerRecordDeviceDriver.cpp derives from NAZWA.dbd
 NAZWA_SRCS += NAZWA_registerRecordDeviceDriver.cpp
 # Build the main IOC entry point on workstation OSs.
 NAZWA_SRCS_DEFAULT += NAZWAMain.cpp
-NAZWA_SRCS_DEFAULT += testFunc.c
 NAZWA_SRCS_vxWorks += -nil-
 # Add support from base/src/vxWorks if needed
@@ -47,6 +46,7 @@
     sncProgram_SNCFLAGS += +m
     sncProgram_SRCS += sncProgram.st
     sncProgram_LIBS += seq pv
+    sncProgram_LIBS += NAZWASupport
     sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
 endif
@@ -59,6 +59,3 @@
 #  ADD RULES AFTER THIS LINE
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of kowalski-jankowalski.1986
Sent: Tuesday, October 06, 2015 10:43 AM
To: [email protected]
Subject: linking C-functions to state machines
Dear Tech-talkers,
I am developing an IOC that will have few state machines often calling function that I have prepared in C.
Minimalistic reproduction of my problem:
When I try to compile my code, I get linker error: NAZWAApp/src/O.linux-x86_64/./../sncExample.stt:15: undefined reference to `testFunction'
collect2: error: ld returned 1 exit status.
If I comment line where I call that function, it compiles and works.
If I understand correctly, I am doing something wrong when telling EPICS to link my C file, I have tried playing with makefile in src, but failed. How should it be done?
relevant files from src:
Makefile:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# Build the IOC application
PROD_IOC = NAZWA
# Build an IOC support library
LIBRARY_IOC += NAZWASupport
NAZWA_LIBS += NAZWASupport
# NAZWA.dbd will be created and installed
DBD += NAZWA.dbd
# NAZWA.dbd will be made up from these files:
NAZWA_DBD += base.dbd
# Include dbd files from all support applications:
#NAZWA_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
ifneq ($(SNCSEQ),)
    # Build sncNAME into NAZWASupport
    sncExample_SNCFLAGS += +r
    NAZWA_DBD += sncExample.dbd
    NAZWASupport_SRCS += sncExample.stt
    NAZWASupport_LIBS += seq pv
    NAZWA_LIBS += seq pv
    # Build sncProgram as a standalone program
    PROD_HOST += sncProgram
endif
# Finally link to the EPICS Base libraries
NAZWA_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
sncExample.stt:
program sncNAME
#include <testFunc.h>
ss ss1 {
    state init {
    	entry {
    		printf("sncNAME: entered init\n");
		when (delay(5)) {
		    printf("sncNAME: Will try testFunction now\n");
		    testFunction();
		} state init
testFunc.h:
void testFunction();
testFunc.c:
#include <stdio.h>
void testFunction(){
	printf("Test Function worked/n");
Regards
Jan Kowalski
linking C-functions to state machines kowalski-jankowalski.1986
Prev: linking C-functions to state machines kowalski-jankowalski.1986
Next: Area Detector: ADPointGrey 2-1 and Blackfly GIGE on Linux John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
