1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: iocLogClient and atExit crash
To: [email protected], [email protected]
Date: Thu, 08 Oct 2015 14:40:21 -0400
It looks like something similar has been done one the 3.15 and 3.16 (logClientDestroy calls errlogRemoveListeners).  Any chance you can test with >=3.15.1 to verify the fix?
Actually, it looks to me like the call to errlogRemoveListeners could be moved to the beginning of logClientDestroy, before the client thread is stopped.
On 10/08/2015 01:53 PM, [email protected] wrote:
> Hi,
> I had an IOC crash during exiting while in logClientSend() - errlogThread() was trying to send a message after logClientDestroy() had already been called by epicsExitCallAtExits(). I was able to remove the crash by adding the line:
> 	epicsAtExit(errlogRemoveListener, (void*)listener);
> to the end of the errlogAddListener() function so that the log client is removed from the listener list before it is destroyed. I hope that is the correct fix.
> This was running base 3.14.12.4 on window x64 compiled with VS 2010
> Regards,
> Freddie
Re: iocLogClient and atExit crash Andrew Johnson
RE: iocLogClient and atExit crash freddie.akeroyd
Prev: iocLogClient and atExit crash freddie.akeroyd
Next: Re: iocLogClient and atExit crash Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
