1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CSS, issue with PVUtil.writePV timeout
Date: Wed, 14 Oct 2015 15:26:48 +0100
Hi All,
I'm using CSS 3.2.16 with BOY.
I have a script to write to some PV using writePV:
timeout = 9
PVUtil.writePV("MyCam:cam1:Acquire" , 1, timeout)
From the documentation, even if not super-explicit, I would assume the timeout is in s.
The writing to PV usually works, but sometimes after a very long time I get a pop-up in CSS saying:
"Failed to write PV:MyCam:cam1:Acquire
Failed to connect to the PV in 9000 seconds.
Reason:
Failed to connect to the PV in 9000 seconds."
This sounds like a bug.
I will try changing the timeout from 9 to 0.009 in the script, but has anybody encountered this problem before?
Isabella
Prev: CSS BOY: file name selection without push [enter] Mauro Giacchini
Next: notification of discard of subscription updates Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CSS, issue with PVUtil.writePV timeout David Michel
