Hi Alex,
You can definitely have 2 two modbus ports pointing at the same registers, one for read and write.
One way to keep your bo record in sync with the coil is to use the following database construct.
record(bo, "$(P)$(R)B0")
field(OUT, "$(P)$(R)BO_write PP")
record(bo, "$(P)$(R)B0_write")
field(SDIS, "$(P)$(R)B0_Sync.PACT")
field(DISV, "1")
field(DTYP, "asynInt32")
field(OUT, "@asyn($(OUTPORT),$(ADDR),$(TIMEOUT))")
record(bi, "$(P)$(R)BI")
field(INP, "@asyn($(INPORT),$(ADDR),$(TIMEOUT))")
field(SCAN, "I/O Intr")
field(FLNK, "$(P)$(R)B0_Sync")
record(bo, "$(P)$(R)BO_Sync")
field(DOL, "$(P)$(R)BI NPP")
field(OMSL, "closed_loop")
field(OUT, "$(P)$(R)BO PP")
The BO record is the record your application writes to. It uses soft device support. It sends its output to the BO_write record that actually does the modbus write. That record is disabled if it is being processed as a result of a callback to the bi record. The BI record is I/O Intr processed when the coil value changes. It writes the value to the BO record via the BO_sync record. Note that I took this example from a non-modbus application so the DTYP and asyn link syntax is probably wrong, but you get the idea.
From: [email protected] [[email protected]] on behalf of Wallace, Alex [[email protected]]
Sent: Wednesday, October 14, 2015 8:51 PM
To: [email protected]
Subject: Modbus Binary Output Readbacks
Can anyone see an issue with modifying the modbus module to give certain records, eg. binary output (bo), two modbus ports to use, one for writes and one to keep the record syncd with the PLC output coil state?
There should be no reason I can see for having two modbus ports pointing at the same registers, one for read and write. But as for the bo record, I'm not really sure where to begin.
Thanks!
-Alex
- Re: Modbus Binary Output Readbacks Mark Engbretson
- Modbus Binary Output Readbacks Wallace, Alex
<2015>
2025
2026
<2015>
2025
2026
