1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn timeout
To: Pedro Gigoux <[email protected]>
Cc: [email protected]
Date: Mon, 19 Oct 2015 17:27:08 +0200
Not with asyn in special, but with all kind of TCP/IP related devices.
TCP/IP has a „Keepalive“, but this is typically 2 hours.
Could you share more information about that "component in the communication chain“ ?
And what happens if the communication is broken ?
Is there a clean FIN on the TCP-layer ?
Is it just dropped ?
Can you run Wireshark on the IOC ?
On the instrument ?
More info is appreciated
Am 19.10.2015 um 16:38 schrieb Pedro Gigoux <[email protected]>:
> Hi,
> We are using asynDriver to talk to an instrument connected to a socket port on a remote site using an ASCII based protocol. The communication works well except that the connection consistently drops when the exposure time is longer than 30 minutes. While the instrument is exposing there's no traffic in the socket; this points to a component in the communication chain that times out if it doesn't see any traffic for more than a certain time. I did not find timeouts in the asynDriver code so I suspect that the problem is in a network switch/firewall. Has anyone seen a similar problem with asyn before?
> Thank you,
> Pedro Gigoux
> Gemini Observatory
RE: asyn timeout Mark Rivers
Re: asyn timeout Pedro Gigoux
Prev: asyn timeout Pedro Gigoux
Next: RE: asyn timeout Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
