1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Modbus TCP communication with PLC IDEC FC5A-D12S1E unable to read Internal Relays
To: Tech talk <[email protected]>
Date: Tue, 20 Oct 2015 18:51:35 +0200
Hello,
I have problems in reading internal relay values from an IDEC PLC. The function code used and the Modbus addresses should be alright, when I set the internal relays (nine of them) all to high and try to debug using asynTrace, I got from modbus port driver:
00 00 00 00 00 00 01 00 00 00 01 00 01 00 01 00 00 00
2015/10/20 16:13:13.014 drvModbusAsyn::doModbusIO port BI READ_COILS
and from drvAsynIPPort driver:
2015/10/20 16:24:46.868 192.168.1.5:502 write 12
00 01 00 00 00 06 01 01 03 e8 00 09
The values from the port driver debug output do not match with the internal relay values and furthermore, when I change one of the internal relay's value, it is not changed in the modbus port driver debug output.
When I try in iocsh >>asynReport:
BI multiDevice:Yes canBlock:No autoConnect:Yes
    addr 0 autoConnect Yes enabled Yes connected No exceptionActive No
    addr 1 autoConnect Yes enabled Yes connected No exceptionActive No
    addr 2 autoConnect Yes enabled Yes connected No exceptionActive No
    addr 3 autoConnect Yes enabled Yes connected No exceptionActive No
    addr 4 autoConnect Yes enabled Yes connected No exceptionActive No
    addr 5 autoConnect Yes enabled Yes connected No exceptionActive No
    addr 6 autoConnect Yes enabled Yes connected No exceptionActive No
    addr 7 autoConnect Yes enabled Yes connected No exceptionActive No
    addr 8 autoConnect Yes enabled Yes connected No exceptionActive No
modbus port: BI
And iocsh for a "BI" modbus port driver:
epics> asynReport 5, "BI"
    enabled:Yes connected:Yes numberConnects 1
    nDevices 9 nQueued 0 blocked:No
    asynManagerLock:No synchronousLock:No
    exceptionActive:No exceptionUsers 0 exceptionNotifys 0
    interfaceList
        asynCommon pinterface 0x7f2bce127ae0 drvPvt 0xd2bcc0
        asynDrvUser pinterface 0x7f2bce128110 drvPvt 0xd2bcc0
        asynUInt32Digital pinterface 0x7f2bce128140 drvPvt 0xd2bcc0
        asynInt32 pinterface 0x7f2bce128180 drvPvt 0xd2bcc0
        asynFloat64 pinterface 0x7f2bce1281c0 drvPvt 0xd2bcc0
        asynInt32Array pinterface 0x7f2bce1281e0 drvPvt 0xd2bcc0
    exceptionActive No exceptionUsers 0 exceptionNotifys 0
    blocked No
    blocked No
    blocked No
    blocked No
    blocked No
    blocked No
    blocked No
    blocked No
    blocked No
modbus port: BI
    asynOctet server:   IDEC
    modbusSlave:        1
    modbusFunction:     1
    modbusStartAddress: 01750
    modbusLength:       011
    plcType:            IDEC_PLC_message
    I/O errors:         0
    Read OK:            2146
    Write OK:           0
    pollDelay:          0.100000
    Time for last I/O   1 msec
    Max. I/O time:      7 msec
I guess that the message connected No points to the problem...but here is where I got stuck.
My st.cmd and .substitution files follow are below.
Best regards
Marek Böhm
My st.cmd:
#!../../bin/linux-x86_64/com_test
## You may have to change com_test to something else
## everywhere it appears in this file
< envPaths
cd ${TOP}
dbLoadDatabase "dbd/com_test.dbd"
com_test_registerRecordDeviceDriver pdbbase
# Use the following commands for TCP/IP
#drvAsynIPPortConfigure(const char *portName,
#                       const char *hostInfo,
#                       unsigned int priority,
#                       int noAutoConnect,
#                       int noProcessEos);
drvAsynIPPortConfigure("IDEC","192.168.1.5:502",0,0,1)
#modbusInterposeConfig(const char *portName,
#                      modbusLinkType linkType,
#                      int timeoutMsec,
#                      int writeDelayMsec)
modbusInterposeConfig("IDEC",0,5000,0)
# drvModbusAsynConfigure("portName", "tcpPortName", slaveAddress, modbusFunction, modbusStartAddress, modbusLength, dataType, pollMsec, "plcType")
#===========BI bits ,,READ ONLY,, Temp is:"BInput.substitutions"=========== drvModbusAsynConfigure( "BI" , "IDEC", 1, 1, 1000, 9, 0, 100, "IDEC_PLC_message")
#===========BO bits ,,WRITE ONLY,, Temp is:"BOut.substitutions"=========== #drvModbusAsynConfigure( "BO" , "IDEC", 1, 5, 200, 200, 0, 100, "IDEC_PLC_message")
cd ${TOP}/iocBoot/${IOC}
## Load record instances
#dbLoadRecords("db/xxx.db","user=swdevHost")
#dbLoadTemplate("BOut.substitutions")
dbLoadTemplate("BInput.substitutions")
#dbLoadRecords("db/com_test.db","USER=swdevHost")
#cd ${TOP}/iocBoot/${IOC}
iocInit
## Start any sequence programs
#seq sncxxx,"user=swdevHost"
#asynSetTraceIOMask("IDEC",0,4)   # Enable traceIOHex
#asynSetTraceMask("IDEC",0,9)     # Enable traceError and traceIODriver
asynSetTraceIOMask("BI",0,4)   # Enable traceIOHex
asynSetTraceMask("BI",0,9)     # Enable traceError and traceIODriver
My BInput.substitutions:
##################################### BI as bits ############################################
file "$(MODBUS)/db/bi_bit.template" { pattern
{P      ,  	 R           ,  PORT , OFFSET,   ZNAM,   ONAM,    SCAN}
####################### 10J Amplifire Moving parts Digital Inputs #########################
{IDEC:,  TEST_IN_0,    	BI,     1,      Low,   High,  "I/O Intr"}
{IDEC:,  TEST_IN_1,    	BI,     2,      Low,   High,  "I/O Intr"}
{IDEC:,  TEST_IN_2,    	BI,     3,      Low,   High,  "I/O Intr"}
{IDEC:,  TEST_IN_3,    	BI,     4,      Low,   High,  "I/O Intr"}
{IDEC:,  TEST_IN_4,    	BI,     5,      Low,   High,  "I/O Intr"}
{IDEC:,  TEST_IN_5,    	BI,     6,      Low,   High,  "I/O Intr"}
{IDEC:,  TEST_IN_6,    	BI,     7,      Low,   High,  "I/O Intr"}
{IDEC:,  TEST_IN_7,    	BI,     8,      Low,   High,  "I/O Intr"}
My bi_bit.template:
# bi record template for register inputs
record(bi,"$(P)$(R)") {
    field(DTYP,"asynUInt32Digital")
    field(INP,"@asynMask($(PORT) $(OFFSET) 0x1)")
    field(SCAN,"$(SCAN)")
    field(ZNAM,"$(ZNAM)")
    field(ONAM,"$(ONAM)")
___________________________________
Ing. Marek Böhm, RP2 Control Engineer
Institute of Physics AS CR, v. v. i.
HiLASE Centre
Za Radnicí 828
252 41 Dolní Břežany
M:    +420 606 259 414
T:    +420 314 007 726
E:      [email protected]
W:    http://www.hilase.cz <http://www.hilase.cz/>
______________________________________________________________________
-- Upozorneni: Neni-li v teto zprave vyslovne uvedeno jinak, neni tato e-mailova zprava navrhem na uzavreni smlouvy ani prijetim pripadneho navrhu na uzavreni smlouvy a nezaklada predsmluvni odpovednost FZU AV CR, v. v. i.
Disclaimer: If not expressly stated otherwise, this e-mail message cannot be considered as a proposal to conclude a contract, neither the acceptance of a proposal to conclude a contract, nor does it create any pre-contractual liability on the part of FZU AV CR, v. v. i.
RE: Modbus TCP communication with PLC IDEC FC5A-D12S1E unable to read Internal Relays Mark Rivers
Prev: Looking at ethercat and EPICS Williams Jr., Ernest L.
Next: Re: SAES NEXTorr NIOPS-04 Vacuum Pump Power Supply Bob Gunion
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Looking at ethercat and EPICS ronaldo.mercado
Next: RE: Modbus TCP communication with PLC IDEC FC5A-D12S1E unable to read Internal Relays Mark Rivers
