You may check the box labeled ³fast update² (or something similar) in the
text control properties. You may also want to experiment with the display
property labeled ³use pixmap². Setting it to ³always² turns on double
buffering which makes things look better for busy updates.
On 10/23/15, 7:44 PM, "[email protected] on behalf of
[email protected]" <[email protected] on behalf of
[email protected]> wrote:
>We notice that EDM updates the screen about twice per second. For
>example, using a text control to display a calc record whose VAL
>increments 10 times a second shows the count incrementing by five
>units every half-second.
>It seems this rate was chosen deliberately. My colleague Stefani Banerian
>found this message:
>http://www.aps.anl.gov/epics/tech-talk/2009/msg00415.php
>which says "the intention was to check each display about twice per
>second".
>She also found these lines in edmMain/main.cc:
> main.cc:1566: stat = thread_create_handle( &delayH, NULL );
> main.cc:1775: thread_delay( delayH, 0.5 );
>We would like to increase the update rate to 5/sec or so. Is any way
>to achieve this without changing source code and rebuilding EDM?
>(This is for simple displays with text controls showing only seven PVs,
>where just one at a time is changing. These would replace hard-wired
>LED displays.)
>Jon Jacky
- Re: EDM display update rate jon
- EDM display update rate jon
Alarm Handler Plug-in for CSS Zeeshan Ali
<2015>
2025
2026
<2015>
2025
2026
