1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: msi for windows IOC build
To: <[email protected]>
Date: Wed, 28 Oct 2015 09:48:55 +0000
Hello,
I am writing because while building an IOC for the PerkinElmer area detector module 2-3, I found that
msi on windows expects ':' as path separator.  This behaviour does not allow to
specify paths for "include" that reside on a different windows drive.
Has anyone else encountered this problem while using msi on windows?
How have you solved them?
My proposal introduces a "-w" switch. The changes are pasted below (changes made against msi 1-5).
I also posted my version at http://controls.diamond.ac.uk/downloads/other/files/patched-msi.c
Ronaldo
--- /dls_sw/epics/R3.14.12.3/extensions/src/msi/msi.c	2013-01-18 20:25:57.045064658 +0000
+++ /home/rjq35657/msi/msi.c	2015-10-21 18:30:29.000000000 +0100
@@ -54,6 +54,7 @@
 /*Exit status*/
 static int exitStatus = 0;
+static int windowsPaths = 0;
 int main(int argc,char **argv)
@@ -87,6 +88,8 @@
 	} else if(strncmp(argv[1],"-V",2)==0) {
 	    macSuppressWarning(macPvt,0);
 	    narg = 1; /* no argument for this option */
+	} else if(strncmp(argv[1],"-w",2)==0) {
+            windowsPaths = 1;
 	} else {
 	    usageExit();
@@ -131,7 +134,7 @@
 void usageExit(void)
-    fprintf(stderr,"usage: msi -V -opath -Ipath ... -Msub ... -Ssubfile  template\n");
+    fprintf(stderr,"usage: msi -w -V -opath -Ipath ... -Msub ... -Ssubfile  template\n");
     fprintf(stderr,"    Specifying path will replace the default '.'\n");
     fprintf(stderr,"    stdin is used if template is not given\n");
     exit(1);
@@ -293,16 +296,17 @@
     const char	*pdir;
     int		len;
     int		emptyName;
+    char        pathSeparator = windowsPaths ? ';' : ':';
     pdir = path;
     /*an empty name at beginning, middle, or end means current directory*/
     while(pdir && *pdir) {
-	emptyName = ((*pdir == ':') ? 1 : 0);
+	emptyName = ((*pdir == pathSeparator) ? 1 : 0);
 	if(emptyName) ++pdir;
 	ppathNode = (pathNode *)calloc(1,sizeof(pathNode));
 	ellAdd(ppathList,&ppathNode->node);
 	if(!emptyName) {
-	    pcolon = strchr(pdir,':');
+	    pcolon = strchr(pdir,pathSeparator);
 	    len = (pcolon ? (pcolon - pdir) : strlen(pdir));
 	    if(len>0)  {
 	        ppathNode->directory = (char *)calloc(len+1,sizeof(char));
Re: msi for windows IOC build Andrew Johnson
Prev: RE: Subject: RE: To read single element from waveform record Mark Rivers
Next: Using V4 pvCommonCPP module with external boost library alan.greer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Subject: RE: To read single element from waveform record Andrew Johnson
Next: Re: msi for windows IOC build Andrew Johnson
