Hi all,
Bit manipulations in a calc or calcout record do not handle bit 31
correctly.
On my 64 bit Linux PC with EPICS 3.14.12, they calculate:
0xaaaaaaaa AND 0xffff0000 = 0x80000000 (wrong)
0xaaaaaaaa OR 0xffff0000 = 0xffffaaaa (OK)
0xaaaaaaaa XOR 0xffff0000 = 0x80000000 (wrong)
~0xaaaaaaaa = 0x55555555 (OK)
~~0xaaaaaaaa = 0xaaaaaaaa (OK)
0xaaaaaaaa >> 8 = 0xff800000 (wrong)
0xaaaaaaaa << 8 = 0x80000000 (wrong)
On my 32 bit Linux PC as well as on Windows 32 or 64 bit
and with EPICS 3.15.2 also on 64 bit Linux I get:
0xaaaaaaaa OR 0xffff0000 = 0x80000000 (wrong)
~0xaaaaaaaa = 0x7fffffff (wrong)
~~0xaaaaaaaa = 0x80000000 (wrong)
0xaaaaaaaa << 8 = 0x00000000 (wrong)
And on my MV5100 (PPC 32 bit) vxWorks with EPICS 3.14.12 I get:
0xaaaaaaaa AND 0xffff0000 = 0x7fffffff (wrong)
0xaaaaaaaa OR 0xffff0000 = 0x7fffffff (wrong)
0xaaaaaaaa XOR 0xffff0000 = 0x00000000 (wrong)
~~0xaaaaaaaa = 0x7fffffff (wrong)
0xaaaaaaaa >> 8 = 0x007fffff (wrong)
0xaaaaaaaa << 8 = 0xffffff00 (wrong)
(Of course when printing the values on 64 bit systems, the values will
be sign extended.)
So all are wrong and even differently wrong. (Maybe someone may add
results for different architectures?)
Here is my test setup:
record (calcout, "DZ:CALC")
field(INPA, "0xaaaaaaaa")
field(INPB, "0xffff0000")
field(CALC, "A AND B")
field(PINI, "YES")
field(OUT, "DZ:LO PP")
field(FLNK, "DZ:MBBI")
record (longout, "DZ:LO")
record (mbbiDirect, "DZ:MBBI")
field (DTYP, "Raw Soft Channel")
field (INP, "DZ:CALC")
field (SHFT, "16")
The reason for the wrong behavior is that conversions from floating
point to integer are "undefined" if the value does not fit.
For the calc record 0xaaaaaaaa is a positive double value
(2863311530.0). But during the bit calculation, it is converted to a
signed integer, long in 3.14, epicsInt32 in 3.15. Since the value is too
large, a correct conversion is impossible and compiler and CPU may do
anything, for example set the value to 0x80000000 or 0x7fffffff.
K&R:
A6.3 Integer and Floating
When a value of floating type is converted to integral type, the
fractional part is discarded; if the resulting value cannot be
represented in the integral type, the behavior is undefined. In
particular, the result of converting negative floating values to
unsigned integral types is not specified.
BTW: "the behavior is undefined" may also legally mean: "abort the
program" or "freeze the CPU".
So we have two problems here with bit patterns using bit 31. Either they
are represented as a large positive floating point number which cannot
be converted to a signed 32 bit integer or they are represented as a
negative floating point number which cannot be converted to an unsigned
integer. Luckily it turns out that the second case seems not to be a
problem on any architecture I tried, even though it "not specified"
according to K&R.
The fix is:
* Before the conversion, cast double value to unsigned integer
* After the conversion, cast to signed integer and then write to double
* For right shift cast double to unsigned first, then to signed, then
shift and last write back the result to double. (This produces sign
extended right shift.)
case BIT_OR:
itop = (epicsUInt32) *ptop--;
*ptop = (epicsInt32) ((epicsUInt32) *ptop | itop);
break;
case BIT_AND:
*ptop = (epicsInt32) ((epicsUInt32) *ptop & itop);
break;
case BIT_EXCL_OR:
*ptop = (epicsInt32) ((epicsUInt32) *ptop ^ itop);
break;
case BIT_NOT:
itop = (epicsUInt32) *ptop;
*ptop = ~itop;
break;
case RIGHT_SHIFT:
itop = (epicsInt32) *ptop--;
*ptop = (epicsInt32) (epicsUInt32) *ptop >> itop;
break;
case LEFT_SHIFT:
*ptop = (epicsInt32) ((epicsUInt32) *ptop << itop);
break;
After the fix I get what I expect:
0xaaaaaaaa AND 0xffff0000 = 0xaaaa0000
0xaaaaaaaa XOR 0xffff0000 = 0x5555aaaa
0xaaaaaaaa >> 8 = 0xffaaaaaa
0xaaaaaaaa << 8 = 0xaaaaaa00
Tested on vxWorks PPC 32 bit, Linux PC 64 and 32 bit, Linux ARM6 LE 32
bit (all gcc).
Can someone test other architectures/compilers?
There is still the general problem of writing double values to integer
fields through a link. This needs to fixed somewhere else in EPICS.
Dirk
The EPICS Archiver Appliance has moved to GitHub. Shankar, Murali
RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
<2015>
2025
2026
Thorlabs FW102C Support? Clark, Mark H
<2015>
2025
2026
