1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asynPortDriver callbacks to I/O Intr, how to propagate an error?
To: "EPICS Tech-Talk ([email protected])" <[email protected]>, "'Mark Rivers'" <[email protected]>
Date: Fri, 30 Oct 2015 17:43:59 +0000
Hi Mark,
I’m sorry to trouble you again, on a different subject.
I refer to http://www.aps.anl.gov/epics/tech-talk/2012/msg00924.php.
I’m using  setParamStatus, for an I/O Intr driven ‘Fault’ value, in my application, to signal alarm status.
There seems to have been a behaviour change between Asyn 4-26 and Asyn 4-27.
When using 4-27, the alarm status on ‘Fault.SEVR’ field is set to INVALID, but the ‘Fault.VAL’ field is not updated with the (non-zero) value that indicates the fault condition.
But if I comment out the setParamStatus call, then Fault.VAL is set to the correct value.
Both values were set as expected, while using 4-26.
Many thanks,
Peter.
RE: asynPortDriver callbacks to I/O Intr, how to propagate an error? Mark Rivers
Prev: RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Next: EPICS Version 4.5 White, Greg
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Job Openings at APS Andrew Johnson
Next: RE: asynPortDriver callbacks to I/O Intr, how to propagate an error? Mark Rivers
