1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Advice on VME processor cards and OS for EPICS
To: David Vine <[email protected]>, <[email protected]>
Date: Fri, 6 Nov 2015 10:04:25 -0600
Hi David,
On 11/05/2015 07:00 PM, David Vine wrote:
>  1. RTEMS. The RTEMS source builder seems straight forward to use but
>     I'd appreciate if someone can recommend a processor, or advice on
>     how to choose one?
If you can find a CPU board that is already supported by RTEMS you will
save yourself quite a lot of work (or money). I think we paid OAR in the
$25K-$30K range to do a port to a new VME board and that was quite a few
years ago. In case you didn't already know, Eric Norum who ported EPICS
to RTEMS now works at LBL, so you have an excellent local source of
RTEMS help just around the corner.
If you do decide to go with VME then RTEMS will make it easier to use
existing EPICS drivers than RT Linux, but be aware that many of those
drivers will have been written for Big Endian CPUs, originally for 68K
family and nowadays PowerPC, and it might take some work to convert some
of them to little-endian should you pick an Intel/x86 derivative CPU.
HTH,
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Advice on VME processor cards and OS for EPICS David Vine
Prev: RE: Building Epics base 3.15.2 in Windows 7 Mark Rivers
Next: RE: Advice on VME processor cards and OS for EPICS Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Advice on VME processor cards and OS for EPICS Michael Davidsaver
