1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: __STDC_VERSION__ weirdness
To: "EPICS Tech-Talk ([email protected])" <[email protected]>
Date: Tue, 10 Nov 2015 11:48:33 -0800
I tried to add some code that uses 64 bit integers:
static epicsInt64
scaleCoefficient(double x)
    epicsInt64 v;
    int neg = 0;
    if (x < 0) {
        neg = 1;
        x = -x;
    if (x > 2) x = 2;
    v = floor(x * (1ULL << 33) + 0.5);
    if (neg) {
        v = -v;
    else {
        if (v >= (2ULL << 33)) v = (2ULL << 33) - 1;
    return v;
To my surprise this failed to compile.  The problem is that this test in epicsTypes.h fails:
#if __STDC_VERSION__ >= 199901L
“Hmmmm", I said, “I wonder how that macro expands”...
238> touch a.c
239> gcc -E -dM a.c|grep STDC
#define __STDC_HOSTED__ 1
#define __STDC__ 1
240>
!!!!!! How can __STDC_VERSION__ be undefined?  I thought it was part of the language.
242> type gcc
gcc is hashed (/usr/bin/gcc)
243> gcc --version
gcc (GCC) 4.4.7 20120313 (Red Hat 4.4.7-16)
And indeed, it *is* part of the language — if you explicitly request a more recent standard.
245> gcc -std=c99 -E -dM a.c|grep STDC
#define __STDC_VERSION__ 199901L
#define __GNUC_STDC_INLINE__ 1
#define __STDC__ 1
wenorum@xildev4 246>
My questions, after that long-winded introduction are, “Given that the default gcc options preclude the use of 64 bit values, what -std value should be used?  Should the appropriate -std=xxxx be added to CONFIG.gnuCommon?"
Eric Norum
[email protected]
Re: __STDC_VERSION__ weirdness Andrew Johnson
Prev: Re: Advice on VME processor cards and OS for EPICS Kevin Peterson
Next: Re: __STDC_VERSION__ weirdness Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS editor [email protected]
