There seems to be a problem with issuing a motor record STOP while we are waiting for a DLY settling time to expire. I can lock up the motor record if I issue a STOP after MOVN has gone to zero and before DMOV goes to 1. This only seems to be a problem if there are no further updates from the driver (so we have already stopped moving). It’s easy to reproduce using a simulation driver.
The problem can be cleared by either doing a SPMG cycle (stop, then go), or by setting any field that would cause a driver callback, which causes record processing, like changing CNEN. At the moment, the DLY seems to be repeated after the problem is cleared. So if I have a 5s DLY, I issue a STOP 4s into it, then I clear it by changing CNEN, then DMOV goes to 1 after a further 5s.
I suspect the desired behavior would be to cancel the delayed callbackRequest that implements the DLY, and not wait for it to expire, at least in this case, since we have already stopped moving then the DLY is probably too long anyway. And probably in other cases I suspect we want a put_callback to complete as soon as we issue a STOP, which is what happens when a STOP is done during a normal move. I can have a go at fixing this if that sounds like reasonable behaviour.
This is motor record version 6-8-1.
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
- Re: motor record DLY and STOP problem Torsten bögershaus
- Re: motor record DLY and STOP problem Torsten Bögershausen
Re: Advice on VME processor cards and OS for EPICS Michael Davidsaver
<2015>
2025
2026
Re: __STDC_VERSION__ weirdness Andrew Johnson
<2015>
2025
2026
