1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS migration and problem with linking container widget
To: "Kasemir, Kay" <[email protected]>
Date: Mon, 16 Nov 2015 10:29:16 +0100 (CET)
Hello Mr. Kasemir,
thank you for your answer. I have checked those new options and i set
them accordingly with our preferences. Unfortunately this change hasn't
fixed the strange behavior.
Our link container widget use a default OPI file while a dedicated rule
change the field "OPI File" accordingly to the (string) value wrote in a
specific PV. During the initialization, the container widget load the
(first) correct OPI (compared to the PV string value), but when we
change the "trigger" PV, the widget doesn't update the OPI link. We have
seen that a refresh screen command let the widget update the panel to
the correct one, but the problem persists when again we change the
trigger PV.
Have you ever tried to use this kind of widget in combination with Rules
dedicated to dynamically change the OPI file?
Thank you in advance for any help you could give us.
Best Regards,
- Maurizio M.
On Nov 13, 2015 08:35 PM, "Kasemir, Kay" <[email protected]> wrote:
> Hi:
> There have been changes regarding the specific resize options:
> Should the container resize to match its content,
> or should the content resize to match the container,
> or should nothing resize and there are scrollbars?
> I’ve seen older displays that don’t work properly without updating
> those (new) options.
> -Kay
> > On Nov 13, 2015, at 11:15 AM, Maurizio Montis
> > Hi to Everyone,
> > i have a question related to CSS control panels and widget: we
> > developed
> > a human-machine interface in CSS 3.2.16 (basic package, 64bit) for
> > our
> > project and it has been in production for about a year.
> > Recently we are trying to move to CSS 4.1.0 (always basic package,
> > 64bit) but we have some problem using the same OPI files: in
> > particular
> > linking containers don't work correctly, showing us a blank window
> > instead of the OPI file desired.
> > We also tried the nightly version (CSS 4.2.0 64bit): in this case
> > the
> > linking container widget is correctly initialized, but the OPI files
> > it
> > has to load don't follow the requirement defined through a dedicated
> > rule.
> > Is there some change related to this widget or related to some
> > particular (new) configuration?
> > Thank you a lot to everyone for any answer.
> > Cheers
> > - Maurizio
> > ~~ Maurizio Montis - Control System Engineer ~~
> >   mobile: +39 3408428089
> >   mail: [email protected]
> >   skype: maurizio_montis
> > Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di
> > Legnaro
> >   V.le dell'Universita', 2
> >   35020 LEGNARO (PD) - ITALY
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
CSS migration and problem with linking container widget Maurizio Montis
Re: CSS migration and problem with linking container widget Kasemir, Kay
Prev: Re: motor record DLY and STOP problem Torsten Bögershausen
Next: CAENels TetraMM Quad picoammeter nick.rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS migration and problem with linking container widget Kasemir, Kay
Next: Alternatives to softGlue? (re-configurable TTL I/O line logic controllable from EPICS) Andrew Gomella
