1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: g_file_read (used in aravislib, areadetector) fails when running on a remote machine via ssh
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 19 Nov 2015 15:00:43 +0100
Hi all,
I am still fighting with glib running within procserv (or remote via ssh).
The aravislib used in areadetector to connect to GigE (Genicam) cameras uses glib.
Running the stuff locally works well. Running it remotely it fails.
Testfile:
h1@earth:~/ARAVIS/aravis/tests$ more loadhttptest.c
#include <glib.h>
#include <gio/gio.h>
#include <stdlib.h>
#include <stdio.h>
#include <arv.h>
int
main (int argc, char **argv)
	GFile *file;
	GFileInputStream *stream;
	const char *filename;
	char *genicam = NULL;
	char **tokens;
	gsize len = 0;
GError *err = NULL;
	if (argc != 2) {
		printf ("Usage: load-http-test <URL>\n");
		return EXIT_FAILURE;
	filename = argv[1];
	tokens = g_regex_split (arv_gv_device_get_url_regex (), filename, 0);
	if (tokens[0] != NULL && tokens[1] != NULL) {
		if (g_ascii_strcasecmp (tokens[1], "http:") == 0) {
			file = g_file_new_for_uri (filename);
			stream = g_file_read (file, NULL, &err);
if (err != NULL) {
             g_error("Could not open %s for reading: %s\n", filename, err->message);
             g_error_free(err);
             return 1;
			if(stream) {
				GDataInputStream *data_stream;
				data_stream = g_data_input_stream_new (G_INPUT_STREAM (stream));
				genicam = g_data_input_stream_read_upto (data_stream, "", 0, &len, NULL, NULL);
				g_object_unref (data_stream);
				g_object_unref (stream);
			g_object_unref (file);
	g_strfreev (tokens);
	printf ("size = %lu\n", len);
	printf ("%s\n", genicam != NULL ? genicam : "NULL");
	g_free (genicam);
	return EXIT_SUCCESS;
Running it locally it shows:
h1@earth:~/ARAVIS/aravis/tests$ ./load-http-test http://141.14.128.47/dias_gige_desc.xml
size = 64451
<?xml version="1.0" encoding="utf-8"?>
<RegisterDescription
        ModelName="Pyroview"
        VendorName="DIAS"
        StandardNameSpace="None"
        SchemaMajorVersion="1"
        SchemaMinorVersion="0"
        SchemaSubMinorVersion="1"
        MajorVersion="1"
        MinorVersion=“ …
	<IntSwissKnife Name="NOT_TLParamsLocked">
		<ToolTip>Negation of the TLParamsLocked value</ToolTip>
		<Visibility>Invisible</Visibility>
		<pVariable Name="TLPL">TLParamsLocked</pVariable>
		<Formula>(TLPL = 0) ? 1 : 0</Formula>
	</IntSwissKnife>
</RegisterDescription>
Running it remote via ssh it shows :
** (process:11455): ERROR **: Could not open http://141.14.128.47/dias_gige_desc.xml for reading: Operation not supported
Trace/breakpoint trap (core dumped)
I assume problems with dbus/session/stream stuff. About one year ago I could overcome the problem by adding the
following to the st.cmd used by procserv :
#!/bin/bash
PID_FILE=/tmp/dbus_pid
if [ -a $PID_FILE ]
  then
#   echo "$PID_FILE exists ..."
    PID=`cat $PID_FILE`
#   echo "kill_pid $PID"
    kill -9 $PID
fi
if test -z "$DBUS_SESSION_BUS_ADDRESS" ; then
  ## if not found, launch a new one
  eval `dbus-launch --sh-syntax --exit-with-session`
  echo "D-Bus per-session daemon address is: $DBUS_SESSION_BUS_ADDRESS"
  echo "$DBUS_SESSION_BUS_PID" >$PID_FILE
fi
#date
#sleep 1
#/usr/local/bin/arv-tool-0.4 -n 'DIAS Infrared GmbH-C1076026' genicam >/tmp/dias_genicam.out
#sleep 1
#date
cd /srv/ioc/sys/iocBoot/iocdias
./st.cmd
#kill -9 $DBUS_SESSION_BUS_PID
But this doesn’t help anymore.
Any Ideas?
Thx Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
[Solved] g_file_read (used in aravislib, areadetector) fails when running on a remote machine via ssh Heinz Junkes
Prev: Control Engineering positions at FRIB bob dalesio
Next: [Solved] g_file_read (used in aravislib, areadetector) fails when running on a remote machine via ssh Heinz Junkes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
